Ac blower motor? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-13-2014, 03:13 PM Thread Starter
Ac blower motor?
So the blower motor stopped working in my truck today. My question is, is there anything else that could cause this? I'd hate to order and replace the blower motor if it's really something else like like a resistor or regulator. Is there any way to tell?
Thanks
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #2 of 6 Old 04-13-2014, 03:15 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I hate to ask a stupid question but did you check the fuse? Does it come on if you switch to heat?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 6 Old 04-13-2014, 04:34 PM Thread Starter
I checked the fuse and changed it with a new one and tried heat. Same result no air flow
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #4 of 6 Old 04-13-2014, 04:53 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I would check and see if your getting power to the motor with a test light.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 6 Old 04-14-2014, 06:23 AM Thread Starter
Well weird thing happened this morning I got in my truck to go to work and the blower motor works now! No idea what's going on with it.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #6 of 6 Old 06-01-2014, 07:28 PM
I don't know if your problem has been resolved, but the issue you are (or will)
experience is the Blower Motor Resistor is going bad.
This will be the 2nd time I've had to replace mine. The weird thing is that
when I search for it using my 2008 F250 King Ranch specs, I get something
that looks like a credit card (YH-1715). But for whatever reason, that part
DOES NOT fit my truck. After I pulled out the resistor and searched for it
online, the part number is (9L3z19e624b) and it looks like a computer heatsink.
So if anybody else runs into this issue, this is what you are looking for:
alby is offline
