sticky hubs - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-08-2014, 02:46 PM Thread Starter
sticky hubs
my right front hub wont turn to unlock whats the best way to free it up
seeder is offline
post #2 of 6 Old 04-08-2014, 02:55 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Pull it and spray it with WD40. If its not too late it should work.
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 6 Old 04-08-2014, 03:17 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Are these hubs the same as the older SD trucks like mine with the o-ring that swells?
If so anything petroleum based will be temporary.
I have hubs without the auto option, and was able to take the dial off and clean then reinstall with lithium grease.
These hubs were so bad you had to use vise grips on them, now 2 years later they both work just like new.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 6 Old 04-08-2014, 05:34 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
I have a brand new hub I bought from ford for like 170 or something like that if your interested I could make you a deal. I bought it because I was told my hub was bad but turns out I had a vacuum leak so I put the old one back in. I have the receipt and part number if you'd like to see it.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #5 of 6 Old 04-09-2014, 03:28 AM Thread Starter
thanks im gona try spraying it first and if it still turns hard ill let u know
seeder is offline
post #6 of 6 Old 04-09-2014, 04:47 AM
Quoted: 9 Post(s)
These hubs can be disassembled , cleaned, re-lubed and put back together...however it is not the easiest thing in the world to do. There's a u-tube video on it that I followed. Sometimes to much grease on the hubs will cause them to stick as well. I've also read some guys clean them and instead of using grease, they use a bit of gear oil on them....not sure if this works though as I've never tried it.
As far as spraying with wd-40....that's prob a temporary solution as it'll hold any sand and grit etc that works it's way behind the dial, which is most likely what's causing it to be stiff now, providing it's not internal damage to the hub mechanism itself.
How to disassemble hubs, Hopefully I'm allowed to past this as it's from another forum? If not my apologies and I will remove the link. Ok as I just read the rules....I'm not allowed to post that link lol...Sorry. However if you google....take apart 2008 f250 auto lock hub, you should be able to find it :-).
Lubricating inner hub bearing,
tofer is offline
