how many of you guys used to have a 6.0? - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 32 Old 04-07-2014, 09:54 PM Thread Starter
How does the 6.4 compact overall? And how do they compare from a reliability stand point?
New truck in the works
wannatruck is offline
post #2 of 32 Old 04-08-2014, 06:13 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
power wise the 6.4 is the winner stock or tuned. interior upgrades and styling is nice. the body style looks good. as far as reliability goes that just depends on what you do with it. my 6.0 was tuned, egr deleted, and exhaust and never really had any problems. my 6.4 is deleted with an h&s and hasnt been any problems either. if you plan to leave the dpf on the truck is where you run into issues. the dpf system is really the only failure point on the 6.4. it creates a lot of stress on the motor so when you delete it, it frees up alot of power and makes the truck very reliable and a runner thats for sure. down side is tuners are expensive and if you dont delete you may run into reliability issues depending on how you drive. only thing i miss about my 6.0 is the sound of it.
imk0001 likes this.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 32 Old 04-08-2014, 06:33 AM Thread Starter
Yeah i do love the sound of my 6.0. I have a studded n deleted 6.0 witha powermaxx n 190 injectors. The the 6.4 I was considering is studded n deleted with a h&s n a built trans n he says new turbos n 60% injectors so im trying to get more details on it.
My 6.0 is a lariat n the 6.4 is a xlt both with the same mileage. Im just trying to decide if I wanna make the switch. The thing that scares me is I know how well my truck runs n when u buy a new vehicle u always r kind of blind folded at first.
My 6.0pulls hard n if I were to get another truck I wouldnt want it to pull less then what mine does now yakno?
post #4 of 32 Old 04-08-2014, 07:10 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
I bought a 6.4 to replace my 6.0, owned them both for a couple years, sold the 6.4
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #5 of 32 Old 04-08-2014, 07:29 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
What made you decide to keep the 6.0 over the 6.4?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 32 Old 04-08-2014, 07:30 AM Thread Starter
^this. What didnt u like about the 6.4? N what stood out to u about the 6.0?
post #7 of 32 Old 04-08-2014, 07:44 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
Part of it was towing my 5er, this has nothing to do with the powerhouse but my 6.0 is a LB dually, the 6.4 was a SB single with a lift and 35s so I prefered the dually for towing. As far as the engine, there was just too many issues with these engines and one is the HPFP witch is known to be weak. Mine went out before I sold it and I had to lift the cab to change it. Lucky for me it was a fail solenoid valve on the pump rather than an exploded pump which sends shrapnel all through the fuel system and turns into a very expensive fix. I sold the truck with a new HPFP on it to a friend and less than a year later, he was doing the same repair again. I am just more comfortable working on the 6.0. I dont have to lift the cab for most repairs but on a 6.4 you cant do much without lifting the cab.
post #8 of 32 Old 04-08-2014, 01:37 PM
Sam Hain's Avatar
If you replace the stock lift pump with an airdog does the cab have to be removed? If you do this before the stocker lets go I assume you don't have to replace the fuel lines etc?
Sam Hain is offline
post #9 of 32 Old 04-08-2014, 01:43 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
No you don't need to lift the cab. It can be installed by dropping the tank or removing the bed.
08 F350 cc/sb 4X4
post #10 of 32 Old 04-08-2014, 01:47 PM
Sam Hain's Avatar
So the stock lift pump is what sends the metal thru the lines correct? Which is a better pump FASS or AD? I know the cummins guys had a lot of trouble with AD.
Sam Hain is offline
