New to diesels! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-05-2014, 06:21 PM Thread Starter
New to diesels!
Hello to everyone. I just recently purchased my first diesel. Its a 08 f250. The truck has a 3 inch lift and 35s, full 5 inch exhaust with the dpf delete, a h & s mini maxx tuner and a bd intake. My question is what kinda mileage should I be seeing from this and what kinda oil do you recommend. Again totally new to diesels as I came from sports cars. Right now I m averaging about 12 to 13 mpg. Thanks in advance.
Atr0989 is offline
post #2 of 2 Old 04-05-2014, 09:51 PM
B585Ford's Avatar
Driving conditions and your right foot will be the biggest factors on mileage. Idling isn't a killer but getting 8k lb truck going from a stop is so if you do a lot of city driving, probably around 11-14. If you are just cruising on the Interstate and can keep it below 70 MPH, that will help. On average, 15-18 on the highway. My personal best ever (hand calculate) was 19.5 IIRCs, but I do have a gear jammer which probably helps.
Oil...personally, I only synthetic in mine. Specifically, run Shell Rotella T6 5W-40.
Make sure you read Aggie's sticky in this section. There is a lot of good info on it for newbies.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
