Metal shavings in oil filter - Ford Powerstroke Diesel Forum
post #1 of 18 Old 04-04-2014, 02:59 PM Thread Starter
StrokiNDieseL's Avatar
08 F-250 6.4L, 48.5K miles fully deleted, recently changed over to Rotella T6 5W40. Upon oil filter inspection I noticed some metal shavings (non-ferrous?) imbedded throughout the filter itself. Only found 1 piece of white rubbed down thin flake, and 1 piece of ferrous metal as seen below. Nothing stuck to the drain plug magnet itself. This is the 3rd oil change since I have owned the truck, but 1st oil filter inspected. Truck was deleted at 38K miles. Blackstone reports seem to give ok feedback and can be seen below. Second report was done after contents found in oil filter, I am questioning if this oil is too thin over traditional 15W40 for higher HP tuned trucks? local shop stated possibly oil pumps low or high pressure breakdown, or any other possible concerns y'all may have that might be going on? Thanks for your time, Jayson.
ID:	267641   Click image for larger version
ID:	267649   Click image for larger version
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
post #2 of 18 Old 04-04-2014, 03:01 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
I don't know but I will tell you the worse oil analysis I've ever had was the one time I tried T6 so I switched back to Motorcraft 15W40
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
The Following User Says Thank You to strokinpower For This Useful Post:
StrokiNDieseL (04-04-2014)
post #3 of 18 Old 04-04-2014, 06:02 PM
srjd's Avatar
Quoted: 2 Post(s)
5/40 and 15/40 are both 40 weight. The first number is just the cold start weight. A thinner oil would be a10/30.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
The Following User Says Thank You to srjd For This Useful Post:
StrokiNDieseL (04-05-2014)
post #4 of 18 Old 04-04-2014, 07:27 PM
E99F350Stroker's Avatar
Well as the old saying goes, Metal flake looks great in paint but not in Oil!
Honestly on a serious note I've always Used Rotella in all of my tractors, and 15w-40 in all of my trucks. I've always thought it is great stuff and it performs accordingly. I personally would just stick to 15w-40 unless Ford recommends something different for newer trucks. My 7.3 is very cold natured and I always manage to get it to start when its cold (I do have to let it warm up for a while or its to sluggish to drive, thinner oil would probably help that). I don't have a lot of experience with 6.4s but I would think that they would start much better because they are not HEUI and therefore thinner oil would not be as necessary at colder temps. Just my .02.
Edit: I reread the OP and I misread the question for my first reply. The metal flakes were found when you initially switched oil brands?
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
post #5 of 18 Old 04-05-2014, 05:55 AM Thread Starter
^^^ I can't say exactly when or how long flakes have been present since this is the first filter inspected. Filter inspection will be a thing for the future as well as changing back to ford recommendations. Thanks
08 F250 6.4L
CcSb Lariat 3.73
post #6 of 18 Old 04-06-2014, 10:21 AM
B585Ford's Avatar
I have run T6 since day 1 and never had issue with it. I look over the old filter but not with a fine tooth comb...guess I will have to look a little closer next time. Wish I could help ya but I am not sure what to think about what you found since your analysis is good. My first instinct would be you (or the previous owner got something in there during an oil change and the filter caught it cause surely if it was an indicator of an internal problem it would have shown up in the Blackstone. Also you would think if that had been in the pan it would have got ground up by all the moving parts. Is there anywhere you could send that debris to get it analyzed. IDK
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
The Following User Says Thank You to B585Ford For This Useful Post:
StrokiNDieseL (04-06-2014)
post #7 of 18 Old 04-06-2014, 03:37 PM Thread Starter
All my research was why I'm on my 2nd T6 fill up. grandpa's giving me chit over the weight.. I'll pull the filter in a 1k or so & see as well as ongoing analysis. Thanks again all, Jayson.
08 F250 6.4L
CcSb Lariat 3.73
post #8 of 18 Old 04-06-2014, 05:17 PM
B585Ford's Avatar
So what did your research say. I am definitely watching this closely. I always thought I was doing my truck a favor by using it, but maybe that ain't right.
B585Ford is offline
post #9 of 18 Old 04-06-2014, 05:57 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
I just changed my oil friday for the second time running T6. i looked at the filter and didnt see anything but im just gonna keep running t6. all the other trucks love it so i dont see why the 6.4 wouldnt. hope you get it figured out
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #10 of 18 Old 04-06-2014, 06:41 PM
What does Ford actually recommend for the 6.4?
Jordan
