Radiator replacement, anything else? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 04-03-2014, 01:01 PM Thread Starter
Fueling M.A.D. Everywhere
CountryAggie's Avatar
I think next weekend I'm going to be replacing my radiator with the mishimoto that came in the mail yesterday. Is there anything else that I should look at doing while the radiator is out (and all the other front end stuff that is required to come out to replace the radiator)?
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #2 of 18 Old 04-03-2014, 03:01 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
All the updated hoses and the t stats if you haven't replaced them already. Also would be a good time to do belt tensioners and idler pulleys if you need to. I think that's about it. Maybe clean out your intercooler while its off??
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 18 Old 04-03-2014, 06:04 PM
I'm planning the same project. I concluded all belts, pulleys and tensioners, the water pump (just for fun), Tstats, gaskets, that's about it. The belts etc were roughly 300 bux and the pump, tstats etc were another 250. It's turning out to be a $1400 to $1500 project.
08 CC SB
Fun Stuff
Mini Max / S&B Intake / 4" MBRP DP / 5" MPRP DP Back / 5" x 6" x 18" MPRP BLACK Tip
Normal Stuff
10" shallow RF sub w/ custom box & amp rack / Xtant 600W amp / Tinted front windows to match factory rears / Recon bed lights
08SuperDiesel is offline
post #4 of 18 Old 04-03-2014, 07:52 PM
Capt dong's Avatar
Quoted: 5 Post(s)
I just did hoses and t stats. Truck wasn't ready for the other stuff at 85k miles.
How many miles does your truck have?
08 F250 KR
08 F250 XL
Capt dong is offline
post #5 of 18 Old 04-09-2014, 05:56 PM Thread Starter
I just broke 100k, my hoses were replaced with the updated ones at 77k. I'll look into the belt tensioner and see how my pulleys look when it's apart.
-Tyler
Texas A&M c/o 2010
post #6 of 18 Old 04-10-2014, 06:57 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
you can see the primary belt tensioner from underneath. what I look for is an even gap between the base and where the arm rotates. When the tensioner starts to fail the arm leans inwards toward the engine.
I look at the belts and tensioners on every 6.4 I work on. I probably upsell these items more often than anything (aside from coolant leaks).
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #7 of 18 Old 04-11-2014, 06:30 AM
muntu's Avatar
I guess you know to be weary about the bolts when you strap your new mishi back in...so as not to puncture it.
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #8 of 18 Old 04-11-2014, 10:21 AM
Did a few searches on this topic here, but didn't really find much on the DIY "how to" for radiator swap.
Any threads, tips, etc?
30 miles into my 6.4L ownership and I've not got a cracked radiator to replace. Needless to say, not happy at all.....
lsc86 is offline
post #9 of 18 Old 04-12-2014, 10:15 PM Thread Starter
Well. It took for freakin ever (because a buddy bailed and I had to do most of it alone), but I finally got it done. Replaced both belts and tensioners. The idler pulleys still looked and spun like new so they stayed. Now in the process of flushing the system with a chit ton of Distilled water before I put ELC in.
-Tyler
Texas A&M c/o 2010
post #10 of 18 Old 04-12-2014, 10:27 PM
B585Ford's Avatar
It looks great....4 hours by yourself aint too bad at all.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
