Air bags and exhaust - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 03-31-2014, 04:34 PM Thread Starter
fordmanmark1's Avatar
Does anybody have any suggestions/experience of exhaust systems that will work with Air Lift bags on my 08 tuck? I have a full delete system with a diamond eye 4" with no muffler from down pipe back and with the passenger side air bag installed, the mandrel bent pipe going over the axel is too close to the frame hence the air bag can't be installed. I've called diamond eye and to no avail on how to nor do they have a pipe to clear the bag. There are no shops that I can find with a 4" die to bend custom pipe. There is more then enough room over the axel to fix the problem just need a exhaust system that will give me the room. Sorry for the lengthily explanation. Any thoughts, remedies,experiences would be appreciated. Thanks
2015 F-350 Platnum FX4 Superduty 4X4 6.7L crew cab Longbed 3.55's 5th wheel prep
Old truck's 95' 7.3 LB EXT 4X4 285,000 miles very much Missed! 08' F-250 6.4 fully deleted
Lots of mods to come
Quote:The right of the people to bear arms shall not be infringed.
fordmanmark1 is offline
post #2 of 13 Old 03-31-2014, 04:39 PM
ZMANN's Avatar
Quoted: 1666 Post(s)
outside the frame bag mounts ?
We Miss you Ronnie
ZMANN is online now
post #3 of 13 Old 03-31-2014, 04:50 PM Thread Starter
Inside, got a very good deal at summit. Allowed me to get the dual pressure gauges and compressor for about the same price. Probably why I'm having the trouble!
post #4 of 13 Old 03-31-2014, 05:05 PM
ZMANN's Avatar
I was suggesting you swap to outside mounts
thats why I don't like the inside mounts to many things can get in the way
fordmanmark1 likes this.
We Miss you Ronnie
ZMANN is online now
post #5 of 13 Old 03-31-2014, 05:07 PM Thread Starter
Yea I might have to. But was hoping for possible alternative solutions.
post #6 of 13 Old 03-31-2014, 05:28 PM
ZMANN's Avatar
I know, I hear ya, I get it
LOL
We Miss you Ronnie
ZMANN is online now
post #7 of 13 Old 03-31-2014, 06:09 PM Thread Starter
I did some research and found the outside mounts and with some summit bucks I was able to come out not too bad to exchange the ones I have and get the outside mounted. will see how this ends up?
post #8 of 13 Old 03-31-2014, 06:12 PM
Tx_oft's Avatar
I've got 5" exhaust on my truck and just installed the air lift bags that go inside the frame. No issues at all. I'm not sure what kind of exhaust it is. I had the shop put it on when they did the motor.
2008 F-250 CCSB FX4, MINI MAX (HD300), K&N CAI, 4" MBRP, ARP STUDS, EGR DELETE, 6.0 ROCKER ARMS, N-FAB STEPS, 6" PRO COMP LIFT, 37X13.50X20 TOYO MT, SMOKED TAILS & 3RD BRAKE
Tx_oft is offline
post #9 of 13 Old 03-31-2014, 06:32 PM Thread Starter
They must have custom bent or welded the pipe. Good it worked for you! Gotta have the bags when your pullin a 5er toy hauler makes it nicer . That's why I'm putting then on.
post #10 of 13 Old 03-31-2014, 06:34 PM
Tx_oft's Avatar
That's why I put mine on. Just bought a 40' toy hauler. Are you monitoring EOT and ECT while towing it? I'm thinking about adding some aftermarket parts to keep all my temps down.
Tx_oft is offline
