dpf removable - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-29-2014, 05:50 PM
strokeit13
Guest
Posts: n/a
Quoted: Post(s)
dpf removable
I have a 2009 f250 and currently not running any sort of programmer in it and not going to because I don't want to do spend the money unless necessary so I was wondering if I could remove the dpf Without having a programmer to increase fuel mileage and I like the sound with it off
post #2 of 4 Old 03-30-2014, 10:08 AM
Quoted: 9 Post(s)
No you can not.....You need a programmer in order to remove the DPF.
tofer is offline
post #3 of 4 Old 03-30-2014, 10:47 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Without an off road tuner your truck will go into limp mode with the emissions gone and the computer not reprogrammed to compensate.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #4 of 4 Old 03-31-2014, 07:15 PM
mohle's Avatar
You will need an off-road tuner capable of deleting the DPF function. Failure to turn off the DPF will result in uncontrolled regeneration - ie. your engine will start to make oil and also go into limp mode. Eventually this will lead to all kinds of other things such as pump and bearing failures etc...
2010 F350 Lariat SC 4x4
2013 35' Gulf Stream Canyon Trail 5th Wheel
2013 Dodge RAM 1500 Quad Cab 5.7 Hemi 4x4
mohle is offline
