Cleaning intake manifold without removing from engine. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-28-2014, 04:55 PM Thread Starter
I removed my EGR after about 20k miles and there's really not much soot in the intake but I want it as clean as possible but without having to take her off the engine.
Also have the Sinister EGR delete kit so it's fairly easy to gain access to it through open port.
I have Snow Performance 625ml nozzle blasting water/meth starting at 16psi and 100% at 33 psi and I think it has help some.
But there's about 3mm of soot left in the intake manifold and it just bugs me.
Any thoughts into maybe cleaning without removing her?
Also do I have to remove the turbos to remove the intake manifold?
Thanks
GSchretter is offline
post #2 of 5 Old 03-29-2014, 06:50 AM
TD-5's Avatar
Quoted: 3 Post(s)
It would be very hard to get that manifold clean inside with it in place, not to mention how much crap would end up down the intake ports. Unfortunately, yes the turbos need to come off to get the manifold out.
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
post #3 of 5 Old 03-31-2014, 06:19 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
At that point you might as well just take it off and install a ported intake manifold.....and some other goodies
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 5 Old 04-02-2014, 04:28 AM
Ditto ^^^^^ Might as well, it would be a great time to do it.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #5 of 5 Old 04-02-2014, 04:35 AM Thread Starter
Excellent point gentlemen. Thank you for your time!
