Any 500,000+/- 6.4's ?? - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 18 Old 03-28-2014, 07:19 AM Thread Starter
rumrun111's Avatar
I am looking for some genuine input. I have a 2000 7.3 cc sb auto srw 4x4 with 238,000. It has absolutely been meticulously maintained and in perfect running order. I haul campers for a living and need a long box. Should I stay with a 7.3 and wait for a long box dually or switch to a 6.4 dually?
Thanks for the input.
rumrun111 is offline
post #2 of 18 Old 03-28-2014, 02:03 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
6.4 has some issues when left stock. if you can find one with low miles and delete the emissions equipment they are great trucks. if left stock you will have more power than the 7.3 but alot more headaches and expensive break downs most likely if your using it to haul daily. one thing you have to worry about is DOT. if your hauling around your area you wont have an issue if you dont have emission inspections but if your traveling around the country you may run into problems with deletes if someone wants to hassle you
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 18 Old 03-28-2014, 02:31 PM
c69ss396's Avatar
just curious why do you "need" a long bed? I tow 5th wheel and GN trailers and I run a 7ft bed. I'd stay with your 7.3....
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #4 of 18 Old 03-28-2014, 02:50 PM
500k in 6 years is a TON of miles....!!
seafordguy is offline
post #5 of 18 Old 03-31-2014, 05:13 AM Thread Starter
rumrun111's Avatar
thanks for the heads up on the out of state DOT inspections.
post #6 of 18 Old 03-31-2014, 05:17 AM Thread Starter
rumrun111's Avatar
When you buy fuel in Indiana, with our lease, it is tax free. I would like to get a 100 gallon auxillary tank and I have not found many large tanks that fit below the bed rails to the 5th wheel camper wont hit them and the distance from the 5th wheel hitch rails to the cab is short. Also, rolling with 16-20 K in camper+truck, the longer truck would be a bit more stable.
post #7 of 18 Old 03-31-2014, 08:11 AM
Eric@PTP's Avatar
Mine has 213 + K miles on it, been deleted from day one. No real issues other than a radiator replaced at 98K miles, all other issues were self inflicted lol. As long as its been taken care of no reason why it shouldn't last just as long or longer than any other diesel.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #8 of 18 Old 03-31-2014, 01:07 PM Thread Starter
rumrun111's Avatar
that is my goal, to remove the weak links and when it is time for the radiator, go with an aftermarket, all aluminum one.
post #9 of 18 Old 03-31-2014, 06:34 PM
c69ss396's Avatar
you need a truck like mine, no hotel bill, 7.3 is proven reliable, over 100gal fuel capacity.... its perfect for what your wanting, no its not for sale. just trying to give you ideas
c69ss396 is offline
post #10 of 18 Old 04-01-2014, 02:59 AM
B585Ford's Avatar
^^^I couldn't agree more....and like was mentioned...if you can find a way to make it have a legal sleeper berth, it would definitely be worth your while.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
