EGT gauge - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-26-2014, 05:15 AM Thread Starter
Sam Hain's Avatar
EGT gauge
Probably dumb question, but I want to run an egt gauge on my truck and wasn't sure if it already had the sensor/wiring in place? I've had gauges on cummins trucks and know the procedure of drilling/tapping the manifold, just wasn't sure on this 6.4
I also have an autometer egt gauge (no probe) just the gauge, can I use it some how?
Sam Hain is offline
post #2 of 4 Old 03-26-2014, 12:51 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Yes there is a pre-turbo EGT. Most the tuners and digital gauges read it off the OBD. I don't know where you would splice into however to connect pillar gauges.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #3 of 4 Old 03-26-2014, 04:19 PM
Mine's read on my H&S tuner from the OBDII port.
2010 F350 Lariat CCLB - The Tow Rig - S&B Intake. H&S MiniMaxx. 4" FloPro DP. 5" FloPro DP-Back.
2001 Explorer Sport Trac - The Trail Rig - Dana44 Solid Axle Swap. Spring over conversion in the rear. Rolling on 35s with ~14" of travel at all 4 corners
01STrunner is offline
post #4 of 4 Old 03-26-2014, 07:38 PM
RobertS450's Avatar
Quoted: 15 Post(s)
If you all ready have the EGT gauge just get a new probe and install it in the passange manifold just like you did on your cummins trucks.
Robert
2010 F450 CC LB 4x4 Black.
RobertS450 is offline
