Need some help Coolant leak - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-24-2014, 12:28 PM Thread Starter
Last weekend i drove the truck and for sure did not have a coolant leak. This saturday morning I was driving it and realized that the heat was not working and the coolant temp on my gauge was getting high so added a gallon of coolant to it.
I drove an hour and a half with no problems and parked the truck in a sand parking lot for 5 hrs. Checked the coolant before i took off again and it was a gallon low again. Drove an hour and a half home with no problems.
Parked it in the garage over night and there was a puddle under the truck the next morning. I have looked under the truck and over the engine bay while its running and cant see it leaking anywhere.
It is hitting the belt because you can see the coolant residue on the underside of my intake piping and intake elbow. It drips down and runs on the front axle and all over the steering components. I started pulling on the coolers off because iam thinking that it is a water pump but what do you guys thing it could be? I am kind of puzzled.
Any help would be apprciated. ( the single turbo and studs are not in the truck yet so pay no attention to my sig. IT DOES HAVE AN EGR DELETE THOUGH)
2008 ccsb F250 lariat
SCT tuned by Gearhead Single 371, MPD CCV RCD pushrods ARPS
SOLD!
2003 f250 4x4 crewcab lariat (03 Turbo)
Perfomance:
ARPs, 175/75 Industrial Injection, EGR delete, 5" MBRP,6.4 Banjo Bolts, Coolant filter SCT Innovative Xtreme X, PHP FICM tuner, AirDogII with Sump
2.5" level, 18" monsters with 33/13.00/18 Nitto Terra Grapplers
powerstroke 825 is offline
post #2 of 13 Old 03-24-2014, 04:09 PM
B585Ford's Avatar
Check the radiator (they always end up leaking) and the hoses. If the hoses have white at the end you have updated double o-ring hoses. If red IIRC, then you have single o-ring that are known to leak. Very good chance it is one of those 2 items.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #3 of 13 Old 03-24-2014, 04:28 PM Thread Starter
The ends are for sure white! Thanks for the help. I guess i will pressure test the radiator.Keep the info coming the guys!
SOLD!
Perfomance:
post #4 of 13 Old 03-25-2014, 07:02 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
If hoses are the updated ones then more than likely its the radiator. Check the drivers side bottom where the tanks are crimped on. That's where mine was leaking. Also just to clarify the old hoses have black ends and the new ones have white.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 13 Old 03-25-2014, 07:25 AM
B585Ford's Avatar
Thanks for clarifying....my bad saying the old ones were red.
B585Ford is offline
post #6 of 13 Old 03-25-2014, 07:28 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
No biggie Brett. You always have a bunch of valuable information. I still have a ton to learn
08 F350 cc/sb 4X4
post #7 of 13 Old 03-25-2014, 01:55 PM
Capt dong's Avatar
Quoted: 5 Post(s)
theres a hose that comes off the water pump and into another hose at the center and bottom of the radiator. follow that hose to the passenger side of radiator. so there are three connections along those hoses where it could leak among many places.
which intake hose/pipe were you referring to?
also check your egr delete plugs particularly the small one near the top front of engine.
08 F250 KR
08 F250 XL
Capt dong is offline
post #8 of 13 Old 03-25-2014, 02:31 PM Thread Starter
I was referring to the one that my air filter is on and the elbow that comes off the manifold
SOLD!
Perfomance:
post #9 of 13 Old 03-25-2014, 02:42 PM
Capt dong's Avatar
Quoted: 5 Post(s)
ok i see what youre saying. long way to travel for the coolant to be hitting your air filter pipe.
08 F250 KR
08 F250 XL
post #10 of 13 Old 03-25-2014, 02:48 PM Thread Starter
Yes i know thats why i feel like it has to be hitting the belt. Unfortunately iam out of town til thursday night so i will not be able to work on the truck until friday but i hope its a line or the water pump. I can see the front of the heads and they do not look wet or have residue on them so im almost certain it did not pop a head gasket. Iam doing studs and other stuff to it in the next couple weeks but i want to do them one at a time if possible!
SOLD!
Perfomance:
