Detroit locker question - Ford Powerstroke Diesel Forum
post #1 of 62 Old 03-23-2014, 01:23 PM Thread Starter
I've got rear end chatter while turning and while under load. Just doing some homework before it gets checked out. I've searched and tried reading up on lockers and the truetrac. I only have a one wheel wonder and know that my ls clutches have been worn out since I got the truck. I was leaning heavily towards the truetrac for on road manors and also for towing vs a locker. Then I read that Detroit has in the last few years changed the way the locker engages. Someone said they have a soft locker or something like that? I was wondering if anyone has a "soft" locker and could share the mannerisms of it on the road? How easily does the locker engage vs the truetrac? Like I said I tow and use my truck for hunting in the spring, fall and winter, but I'd say 80% of the time it's on the street. I've read that most people are very satisfied with their truetracs but there are some that say they wish they'd got the locker. There's been many times this winter that one tire would be on dry pavement and the other on ice and I'd have to put it into 4x4 just to take off.... Annoying....
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #2 of 62 Old 03-23-2014, 04:58 PM
Powerstroke Techie
Quoted: 15 Post(s)
Garage
Feedback Score: 4 reviews
What you're going to find out with a truetrac or a locker is that you're not gaining a whole lot of extra traction in an unloaded pick-up truck. You're still going to need 4wd and you may need it even more in slippery conditions to keep from totally losing control of the rear end. Yes in mud and gravel it is nice to have, in snow and ice you should have it in 4wd all the time.
I wrecked the truck this year and it started by losing the rear on the interstate in some pretty bad conditions. If I would have had it in 4wd it wouldn't have happened. If I didn't have a limited slip it also might not have happened.
For whatever it is worth my truetrac has never let me down. I don't know it's back there and it's never one wheel peeled. I've got at least 40k miles on it
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 62 Old 03-23-2014, 05:31 PM Thread Starter
Have you ever had to "trick" the rear end and tap the brake to make the truetrac lock up? I've read that on here a few times. Some never had to do this but some have. Seems like if you're in a situation and had to do this that tapping the brake would be the last thing on my mind to do.
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #4 of 62 Old 03-23-2014, 05:36 PM
ZMANN's Avatar
Quoted: 1589 Post(s)
I have been researching
if u read Eatons website it looks like the Detroit is still noisy and harsh and really aimed for a different crowd than the DD unlike the Detroit truetrac
We Miss you Ronnie
ZMANN is offline
post #5 of 62 Old 03-23-2014, 06:41 PM Thread Starter
I was also looking at their site. Would the old "Detroit locker" be the eaton m locker? That seems a lot like the locker in my Tahoe. I talked to them a while back about something else and the rep from eaton said they make the lockers for the newer Chevys and the one in my Tahoe they said that it locks when there is a 100rpm difference but only operates like that under 30 mph. The m locker is a limited slip (not open diff like the truetrac until it engages) until the 100rpm difference so you can turn, then it fully engages.
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #6 of 62 Old 03-23-2014, 06:44 PM
ZMANN's Avatar
m locker ? I don't know it took me forever to get the Detroit and the Detroit Truetrac sorted out LOL
We Miss you Ronnie
ZMANN is offline
post #7 of 62 Old 03-23-2014, 06:46 PM Thread Starter
Haha, for real! Here is their site I was looking at.
Differentials & Locking Differentials
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #8 of 62 Old 03-23-2014, 06:51 PM
ZMANN's Avatar
thx thats the site I used also and Jegg's
so the " no spin is the one most list as the Detroit I think LOL here is the actual Eaton detroit page http://www.eaton.com/Eaton/ProductsS...als/PCT_221432
I started this when a guy listed a Detroit truetrac but linked to the Detroit
on jeggs site turns out his was a no spin and even though they were way more money and He had a smoking deal but I had no desire for that unit
We Miss you Ronnie
ZMANN is offline
post #9 of 62 Old 03-23-2014, 06:58 PM Thread Starter
The m locker doesn't sound like it'd be too bad for a non trail/offroad rig. I always assumed that full lockers were locked 100% of the time. This does allow somewhat for turning the inside wheel to spin slower.
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #10 of 62 Old 03-23-2014, 07:00 PM
Powerstroke Techie
Quoted: 15 Post(s)
Garage
I have never had to trick my truetrac into locking up. Generally you can tell when both wheels are spinning when the rear end wants to walk out on you. By that time you're already wishing you were in 4wd
Full lockers are locked in when you're going straight and unlock to allow the wheels to spin different speeds when turning. Truetracs are not always locked in and bias torque to the wheel with most traction.
-Matt
2015 F-250 XLT 6.7L
