Small vibration. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-23-2014, 05:40 AM Thread Starter
floorboy's Avatar
Small vibration.
I get a little vibration when taking off from a dead stop. Hard to explain, only at slow speed under a slight load. I saw something about greasing splines on the driveshaft?? Could that be it? Got a link? Thanks.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #2 of 5 Old 03-23-2014, 06:00 AM
E99F350Stroker's Avatar
Do you know for sure that it is coming from the drive shaft?
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
post #3 of 5 Old 03-23-2014, 07:55 AM Thread Starter
floorboy's Avatar
No I do not. Ideas??
floorboy is offline
post #4 of 5 Old 04-24-2014, 06:52 PM
My u joints finally went out. I was getting vibration under light foot pedal, and I was also getting a squeaking when backing up (didnt think much of the squeaking). When I took my driveshaft to the shop, he asked me about any noice backing up, and said that was a sign (I never mentioned it to him before that).
tictactowing is offline
post #5 of 5 Old 04-24-2014, 08:04 PM
WoodBoy's Avatar
Usually its either a U-joint going out or a carrier bearing spacer problem which I don't think you have? So it's probably a u-joint. Take a bar and run up between it and twist it back and forth and look for any side to side play between the driveshaft and yoke.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
