Oil change after delete - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 24 Old 03-18-2014, 04:18 AM Thread Starter
dnaber's Avatar
Now that I'm deleted and tuned, can I still take my truck to my local dealership for a oil change? Would I have to detune and put the CAT/DPF back on? because if thats the case forget it!!!!
I do plan on doing my first one myself, but if it's more of a PITA then I may source it out after.
Thanks
Don
Don Naber
USAF (Retired)
Middleburg, FL.
God Bless America, And All That Serve This Great Nation
dnaber is offline
post #2 of 24 Old 03-18-2014, 04:30 AM
Quoted: 3 Post(s)
Are you still under warranty?
If not, then I don't think it matters.
I would be more inclined to take it to an independent mechanic.
I see that you're in Middleburg. I'm in Jax. I have a reputable mechanic near SS and Beach Blvd if you choose that route.
The_JRuss is offline
post #3 of 24 Old 03-18-2014, 04:37 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
This may be a silly question, but why not just do your oil changes yourself? It takes all of 20 min and that way you know the correct oil (and amount) is in it.
-Pull the drain plug (wait 30 sec and get an oil sample if you are going to send one)
-Remove the fill cap
-Remove the oil filter (it takes a 36mm socket to remove the plastic cover. Also the same socket required for your fuel filter caps).
-Put in new filter
-Put in drain plug
-Fill with 15qts of quality oil
-Reinstall fill cap.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #4 of 24 Old 03-18-2014, 04:40 AM
Quoted: 3 Post(s)
Yeah I would lean towards doing the oil change myself also.
Especially knowing that the temptation for a shop to stomp on a 600HP/1100lb truck is always going to be there when they test drive it.
post #5 of 24 Old 03-18-2014, 04:50 AM Thread Starter
dnaber's Avatar
I fully agree!!!!
Where have you guys found an oil catch pan that will hold 15 -16 quarts of used oil?
And where have you found the best source for getting your oil filters?
Don Naber
USAF (Retired)
Middleburg, FL.
dnaber is offline
post #6 of 24 Old 03-18-2014, 04:51 AM
Sam Hain's Avatar
Coming from a 3rd gen 5.9 cummins the oil change on the 6.4 is a breeze. Do it yourself.
Sam Hain is offline
post #7 of 24 Old 03-18-2014, 04:53 AM
Sam Hain's Avatar
Originally Posted by dnaber View Post
I fully agree!!!!
My local autozone carries the motorcraft oil filter FL2016, I jack the truck up and use a 5gal bucket to catch the oil. The standard drain pans at auto parts stores won't hold it all.
Sam Hain is offline
post #8 of 24 Old 03-18-2014, 05:28 AM
I fully agree!!!!
I got a oil catch can at oriellys a while back. It holds 5 gallons. 16 qts is 4 gallons so it's plenty of space.
GSchretter and The_JRuss like this.
-Tyler
Texas A&M c/o 2010
post #9 of 24 Old 03-18-2014, 05:30 AM
If you gotta jack the truck up to get a 5 gallon bucket under it's sittin too low! just givin you chit. I actually don't know if a bucket would fit under mine. Never tried.
-Tyler
Texas A&M c/o 2010
post #10 of 24 Old 03-18-2014, 05:35 AM
Sam Hain's Avatar
I've got a dually it sits lower than 3/4 tons.
Sam Hain is offline
