help! downpipe install - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-15-2014, 10:46 AM Thread Starter
trying to install sdp downpipe. the collar on the factory clamp is stuck and wont release. also, how did everyone get the factory tab from the dp to the turbo off? really stuck and pissed off!!! please help!!!
AquaAddict is offline
post #2 of 4 Old 03-15-2014, 02:07 PM
At the top or bottom?
Fussgus is offline
post #3 of 4 Old 03-15-2014, 02:45 PM
Capt dong's Avatar
Quoted: 5 Post(s)
wiggle it around from the top and bottom. you might have to use a pry bar. it eventually pops off.
08 F250 KR
08 F250 XL
Capt dong is offline
post #4 of 4 Old 03-15-2014, 04:59 PM
StrokiNDieseL's Avatar
Remove clamp entirely, from bottom move bk/4th. Up top pull up to clear factory dp hook to turbo & cut her loose after she drops. Good luck, Jayson.
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
