Egr delete question - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-14-2014, 06:57 AM Thread Starter
Egr delete question
I going to be deleting my egr with sinister delete kit with elbow. I was wondering do I need to flush my radiator or can I just add coolant?
wizlams08 is offline
post #2 of 19 Old 03-14-2014, 06:59 AM Thread Starter
Everything I've read doesn't mention either I have to flush or I can just add coolant like 50/50
post #3 of 19 Old 03-14-2014, 07:02 AM
I haven't done mine yet but I would just kept track of any lost coolant during install and replace after completed. Do not use 50/50! Make sure it's the ford gold or comparable brand.
Kris 6.4 is offline
post #4 of 19 Old 03-14-2014, 07:07 AM Thread Starter
Oh ok well I don't have time to get the Ford gold so I'll have to find a comparable brand
post #5 of 19 Old 03-14-2014, 07:10 AM
Quoted: 2 Post(s)
i would not mix another brand with the ford gold. If your truck has ford gold and you aren't completely flushing, you are making a mess of your cooling system.
get the ford gold if you aren't flushing, otherwise, do a complete flush and get some CAT ELC coolant.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #6 of 19 Old 03-14-2014, 07:14 AM
Clayton1985's Avatar
You'll lose about 5 gallons, IIRC. You could get away with just adding water for the time being (if ya dont live in the cold) until you get the time to either dump and add ford gold or flush....whatever your plans are.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #7 of 19 Old 03-14-2014, 07:19 AM Thread Starter
Well I live in pa and yesterday was a high of 11*f so I guess I'll have to get to a ford dealer and get some. So I just need like 3 gallons then finish the rest with distilled water?
post #8 of 19 Old 03-14-2014, 07:32 AM
Sam Hain's Avatar
I used the zerex G-05 is it the same as ford gold?
Edit: After a little research looks like ford gold and the zerex are the same other than the ford gold is full strength and the zerex is cut 50/50 ready to pour.
Sam Hain is offline
post #9 of 19 Old 03-14-2014, 07:33 AM
Sam Hain's Avatar
To the OP, I did re-use some of the coolant that came out. It did have sand in it, most of it settled to the bottom of the bucket but just to be safe I filtered what I put back in.
Sam Hain is offline
post #10 of 19 Old 03-14-2014, 07:39 AM
Capt dong's Avatar
Quoted: 5 Post(s)
as said i wouldnt mix. also i would put back what was caught and top off with distilled water.
do a proper flush when youre ready and fill with cat ec1 rated coolant and add a filter. deleting egrs will make tstat access extremely easy when youre doing a flush.
08 F250 KR
08 F250 XL
Capt dong is offline
