H and S Mini Max - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 27 Old 03-13-2014, 06:09 PM Thread Starter
H and S Mini Max
Just wondering what problems anyone has had with there trucks after installing mini max. I've put 30000 miles on my truck since installing mini max egr and cat dpf delete but tomorrow I'm taking my truck to the third mechanic to fix it whatever the case maybe the first two said hpfp. The mechanic I am letting diagnose and work on my truck seems to be very good with the 6.4 I have known him since I bought my truck three years ago and I believe him to be honest. He has doubts about the mini max and says it can effect my truck even though I run low power settings. What are you alls thoughts on this?
08 King Ranch 6.4 is offline
post #2 of 27 Old 03-13-2014, 06:50 PM
TD-5's Avatar
Quoted: 3 Post(s)
Of all the tuners available H&S is one of the best & safest out there.
'086.4LDiEsEl' likes this.
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
post #3 of 27 Old 03-13-2014, 09:40 PM
If it's the hpfp then it's not the mini maxx and I highly doubt it's the tuners fault no matter what the problem is. Hpfp failures are common on 6.4's. I think the general consensus is not IF it fails but, WHEN it fails. Mini maxx is one of the best out there for our trucks. I wouldn't note it as the cause of any problems
2006 F250 EC/SB - SOLD
2010 F250 CCSB
Spartan, 5" dp back exhaust, s&b intake, fuel boost 18x9, 315/70r18 toyo mt
06psd6.0 is offline
post #4 of 27 Old 03-14-2014, 06:09 AM
I was told when i did the same exact mods as you if i did not go with a fuel system like FASS i would end up having to replace the hpfp down the road which would be more expensive than the FASS. Im fairly new to diesels so i have no idea why they said this, I did not go with the FASS I was about to but am leaning towards the setup Fuel Labs is putting out in another couple weeks i am told that will not need a sump as an extra bonus
dfauerbach is offline
post #5 of 27 Old 03-14-2014, 06:22 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ What he said. Get either the fuel lab setup or the airdog 2. Better filtration/water separation.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 27 Old 03-14-2014, 06:36 AM
Was also told that injectors would be next another expensive job because of the air in the fuel
post #7 of 27 Old 03-14-2014, 09:42 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I use the Baldwin water separator and Donaldson filter for the best possible filtration/water separation.
08 F350 cc/sb 4X4
post #8 of 27 Old 03-14-2014, 09:46 AM
which model Baldwin
post #9 of 27 Old 03-14-2014, 09:49 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Originally Posted by dfauerbach View Post
which model Baldwin
Baldwin BF1275 and Donaldson P551315
08 F350 cc/sb 4X4
post #10 of 27 Old 03-17-2014, 12:35 PM
B585Ford's Avatar
You can get a Fuel Lab through Midwest and in a few weeks Side Action Diesel so that it will work on a 6.4 but I haven't heard that Fuel Lab will be releasing their 6.4 version in a few weeks. Do you have a link to that?
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
