easy out or bolt extractor success on exhaust manifold - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By zsargent
post #1 of 10 Old 03-11-2014, 09:21 PM Thread Starter
I have a bolt broken on my drivers side rear exhaust manifold. before I try to pull the manifold and risk breaking any other bolts , has anyone had any success getting broken bolts out of the head using these methods. Only the head of the bolt broke off so there is still about 2 inches sticking out of the head itself
Thanks in advance guys
maverickxp is offline
post #2 of 10 Old 03-13-2014, 05:25 PM
B585Ford's Avatar
I don't have any advice that would be helpful for this, but good luck
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #3 of 10 Old 03-13-2014, 06:07 PM
Had similar problem with broken off bolt head on my backhoe turbo exhaust housing.
I also still had some bolt left to grip. I was successful soaking thread area with PB blaster several times during day and was able to break loose with large vice grips without problem the next day. The PB blaster needs some time to work down the threads.
2008 F350 6.4 4x4 DRW CC 4:10 King Ranch Job3
Max2006 is offline
post #4 of 10 Old 03-13-2014, 06:23 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
You might be able to weld a nut to the broken bolt if you have enough sticking out. Plus the heat will help it break loose
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #5 of 10 Old 03-13-2014, 09:23 PM Thread Starter
This is the broken bolt. I'm afraid to remove the manifold and break any more bolts. What are your thoughts
Name:	2014-03-14 00.19.02.jpg
post #6 of 10 Old 03-14-2014, 12:18 AM
theplumbingmedic's Avatar
Oh that looks painful.Good luck, let us know how it ends up
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #7 of 10 Old 03-14-2014, 01:31 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Torch... everybody should invest the 200$ for a set of torches.
Heat the heads on the rest of the bolts, and let them cool a couple times. Then heat again till almost red and they should spin right out.
Then remove the manifold and torch whatever is sticking out of the broken bolt and it should wiggle free with some vice grips. I'm not sure how much room you have in there though.
Soaking with penetrant for a few days helps too, but nothing beats a torch for exhaust bolts.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #8 of 10 Old 03-14-2014, 01:45 AM
THIS IS HOW WE DO IT....
Quoted: 215 Post(s)
Negative Schlutzer. these are bolts, not studs. if you heat the heads you'll twist them and break them and if you heat the entire bolt red you risk damaging the engine head.
I owned two exhaust shops for many years and I've done countless broken bolts and exhaust manifolds....
Maverick,
Soak the bolts in PB blaster, or better yet use "mouse milk". Amazon sells it for about $10 a bottle. A little goes a long way... we use it extensively in the aviation industry. It'll loosen everything. be generous and patient. Your only choice here will be to remove the other bolts and get the manifold out.
Get some vice grips, or better yet, if you can, weld a nut on the broken bolt and back it out.
When you've got all of them out; clean the threads in the head and install STUDS back in. Not bolts. Try using SS ones. It'll make it way easier if you have to remove exhaust manifold next time around.
hope this helps and good luck.
GSchretter likes this.
Zach
07 F250 King Ranch FX4 CCSB, Dark Copper Metallic/Arizona Beige, Rotella T6+Archoil
6000K HIDs, Fog mod/High Idle, Tinted,
Banks CAI, Blue Spring, NUC/Amsoil Bypass Oil Filter
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
138,000 miles....
Air Force Veteran......Go Blue!
"Think of the most attractive person you know. Even that person, at some point, has had raging diarrhea"
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #9 of 10 Old 03-14-2014, 01:49 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Maverick,
That's why you heat them multiple times and on the last time don't go red hot... Trust me it works I've done it many times. Obviously being careful what you let get hot and how much force you put on the bolts
I totally agree on your putting studs in instead of bolts though. Much better way for it to be
post #10 of 10 Old 03-14-2014, 06:55 AM
Capt dong's Avatar
Quoted: 5 Post(s)
good luck with this. i think a homemade mixture of trans fluid and acetone tested the best out of many penetrants. im finishing a can of pb blaster so i can mix a solution of my own.
08 F250 KR
08 F250 XL
Capt dong is offline
