baldwin filters - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-11-2014, 12:32 PM Thread Starter
baldwin filters
Ive always used motorcraft filters and did all the changes on my truck myself, at least in the last two years I owned. I know everyone says use motorcraft, but I can get Baldwin cheaper. the fuel and oil filters look like the same thing. I heard they are an excellent product. what do you guys think????
nocturnal30 is offline
post #2 of 4 Old 03-11-2014, 02:49 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I use a Baldwin filter for the water separator on my airdog. I also use it as a coolant filter and bypass tranny filter. Not sure about using it in the stock housing tho.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 4 Old 03-12-2014, 04:38 AM
Sam Hain's Avatar
If I were in your situation I would buy the baldwin's and compare them to the motorcraft filters. The biggest issue I was aware of comparing aftermarket market filters to OEM was the membrane on the water separater and the height of the oil filter. If all those check out then I wouldn't see a problem running them. I just order my fuel filters from dieselfiltersonline.com, my local autozone carries the motorcraft oil filter.
Sam Hain is offline
post #4 of 4 Old 03-12-2014, 06:04 AM
We use the Baldwin oil filter and fuel filter kit in my dad's 6.4 granted he is very meticulous on 5k oil change and 10k fuel in the summer and winter time we change the fuel filter every time the oil is changed. No problems yet but he only has 53,XXX on his job 2 08
Dan2427 is offline
