How i primed the 6.4 fuel system - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-10-2014, 01:21 PM Thread Starter
Crawler374's Avatar
My idea may already be on the forum, but as a dodge tech, I was not familiar with the 6.4 fuel system. The truck I worked on was a 2008 f450 6.4. The truck was throwing the water in fuel light. I tried to simply pull the lever and drain it but after draining it 10 times, I constantly saw mold coming out of the valve. I got both new fuel filters (frame mount and high mount filters). I do fuel filters on the cummins all the time, and boy was I in for a task after doing the powerstroke. I ended up having to remove the filter/pump housing, take it apart and clean it out. It was inreal how much mold was growing in there. Previous owner obviously has not changed the filter in a long time. I was not aware of the procedure everyone online goes by. Anywho, I did them both at the same time. Therefor all lines were dry.
After 3 hours on trying to prime the system, I got desperate and decided to hook air into the filler cap and forced the fuel up top (with the fuel pump running) and it FINALLY primed. The first time I hooked air, I had the engine mount fuel filter out and pushed air in the fuel tank until it filled the bowl. Then I put the new filter in and cracked the banjo bolt on the fuel fitting and hit it with air again until a solid stream of fuel came out. About 10 seconds of turning the engine over, it finally crank up and ran. No sputtering, no hesitation; full power.
Im sure someone here will tell me hooking air to the tank is a very bad idea, and it might be. But as desperation came, it was the only thing that worked for me. Maybe it will help someone out in the future
1992 F350, 351 Windsor, 4 door long bed. Not serious mods right now.
Crawler374 is offline
post #2 of 4 Old 03-10-2014, 01:24 PM Thread Starter
Crawler374's Avatar
I must point out that I DID NOT PUT SHOP AIR IN THE TANK! I had a hand held air valve and barely let air in the tank. I would guess I had about 2-5psi in the tank. just a rough estimate.
post #3 of 4 Old 03-10-2014, 01:28 PM
ZMANN's Avatar
Quoted: 1462 Post(s)
it seems like something had to be a restriction for the air PSI to overcome what a normal key cycling procedure would not
as far as air into the tank I commend u on getting er done
i see you didn't use shop air = smart
but to anyone who tries this u would be shocked at what even 5 psi can do to the shape of plastic fuel tank if not vented so be very careful
We Miss you Ronnie
ZMANN is online now
post #4 of 4 Old 03-10-2014, 02:00 PM Thread Starter
Crawler374's Avatar
Well the pump is in the filter housing. it was 100% air when I put it back in. Fuel pump was priming air, and had no fuel to make a suction. I tried putting fuel into the lines at the upper filter to fill up the lower filter, but it was not working for me.
As for the psi in the tank, I agree! It was a little sketchy, but I knew it was pushing fuel out of the lines and not over pressurizing the tank, so I wasn't too stressed about it.
