Truck swerves @ high speeds - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-09-2014, 05:39 PM Thread Starter
Got an 09 f250 crew short box, ive raised the rear end 1.5" and put pro comp traction bars on. This thing won't stay on the road. I get pulled to the left and the right mostly above 50 mph. Is this a trac bar issue? If so, what is the recommended fix? It's driving me insane!
Thanks in advance.
09powerstrokee is offline
post #2 of 3 Old 03-10-2014, 12:07 PM
Did it do it before the bars were installed?
cuda66 is offline
post #3 of 3 Old 03-10-2014, 12:42 PM Thread Starter
It did not do it before the bars were installed. I always thought that had nothing to do with the front end. I just did traction bars to prevent axle wrap. Funny thing is, my truck has some vibration from the line and at high speeds, I know I need a carrier bearing shim kit in it since I raised the rear end, that will be installed this week. But as for the rest, I'm at a loss. I might take the traction bars out to see if anything is different.
