6.4 Catastrophic Failure after DPF & EGR Delete - Ford Powerstroke Diesel Forum
post #1 of 25 Old 03-07-2014, 06:20 PM Thread Starter
SixOhPowerstroke's Avatar
Quoted: 2 Post(s)
Had a customer bring in a 2008 that he wanted deleted. Ran just fine when it came in, no issues, 77k miles. Did the deletes with an h&s tuner and set it on tow. Started up fine ran great sounded great. So a guy a work with took it for a test drive. Drove great with plenty of power. Boss took it for a test drive, came back about 30 minutes later, white smoke pouring out of exhaust, bad engine knock. Opened oil cap, tremendous blow by. Oil and coolant level still fine. So my boss is disgusted and says we are looking at a motor job next week. What the f**k could have happened here?
2005 F-350 Reg cab Fx4 - Deleted, updated, bullet proofed. TSD tuned. 18x10 moto metal 962's, 35x12.50 federal mt's, 2'' level, mbrp exhaust, ect, ect. Western Ultra Mount 8' Plow. Money maker/work horse.
SixOhPowerstroke is offline
post #2 of 25 Old 03-07-2014, 07:26 PM Thread Starter
Quoted: 2 Post(s)
Any one have an idea? These trucks were starting to grow on me but we have already had 3 6.4 engine jobs, one was already deleted. These motors are such pieces of sh*t it's not even funny any more.
post #3 of 25 Old 03-07-2014, 07:47 PM
Motors are junk. Stick to 6.0's and Duramax's…
seafordguy is offline
post #4 of 25 Old 03-07-2014, 07:53 PM Thread Starter
Quoted: 2 Post(s)
At first and for a while actually i used to think 6.0's were lemons. But once fixed right, they last. Never had any come back to the shop. 6.4's make power but it just seems like they blow up whenever they want..
post #5 of 25 Old 03-07-2014, 08:27 PM
blitzin247's Avatar
wow man, I feel terrible for your boss....thats alota cash to drop for a test drive with a freak accident..my sympathies.
1994.5 7.3 ZF5 ECLB Reman stock sticks, LUK Clutch and single flywheel conversion, all stock and looking to mod.
Totaled 7/24/14 600hp 04 LB7 CCSB with some goodies
Jesus loves YOU, have YOU asked Him to be your Savior yet?
-http://www.powerstroke.org/forum/signaturepics/sigpic138659_2.gif-
blitzin247 is offline
post #6 of 25 Old 03-07-2014, 08:54 PM
B585Ford's Avatar
Best guess....with the blow by I would say you most likely have cracked piston...maybe with a leaky injector contributed. If it turns out to be a cracked piston without a leaky injector, the crack was probably there (and small) before you ever started working on it unless your boss was hot rodding it pretty good...but this is probably a case of REALLY bad luck for you guys. Sorry to hear it.
6.4 factory pistons are definitely problematic. My truck is in the shop getting some goodies, but I had the guys do their best with a scope (heads aren't coming off) just to look for any evidence of a crack. The cracks usually start at the lip.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #7 of 25 Old 03-07-2014, 09:15 PM
srjd's Avatar
Quoted: 2 Post(s)
The 6.4 is actually a great engine. The problem is the the emissions for the most part and owners who think they are driving a 7.3 and maintenance can go by the wayside. I will admit the 6.4 does have some downfalls but if taken care of properly there's no reason it won't last. We are starting to see lots of guys over 300k now with minimal issues. Also if these 6.4 are neglected they will be nothing but a headache.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #8 of 25 Old 03-07-2014, 09:32 PM
srjd's Avatar
Quoted: 2 Post(s)
Not to contradict myself but there are some 6.4 stories where guys claim they were religious with maintenance and they are on there 3rd engine. I guess every brand has lemons out there
srjd is offline
post #9 of 25 Old 03-07-2014, 09:38 PM
B585Ford's Avatar
I agree the 6.4 has some great features. Like all engines, it has flaws too, but maintenance is a definite need with the 6.4 and the emissions crap really helps expose the flaws
Problems:
Radiator - Junk
Early radiator hoses - not very good
Early degas setup - bad
Factory water separator - less than optimal
Pistons can be a definite issue especially on tuned trucks and high HP trucks - definitely can be problematic
Plastic Clips and Rocker oiling -not great and is a problem on non-DPF deleted trucks
K16 does seem to hold up quite as well as a CP3
Like is the case with all common rails, a leaky injector will melt the piston if not caught early (and that isn't always possible)
Up pipe failures especially on tuned trucks
Goods:
Bottom end is very stout (unless you count pistons) - as strong as anything made in this century
Stock turbos to hold up well even at 550-600HP
Compound turbos
Power potential
Valvetrain - other than mentioned above, very good from the factory
Very stout factory auto and manual trannies and good overall drivetrain
Factory IC works well for its intended use and holds up well except the earlier builds having condensation issues
I am sure I missing a few things, but that's my basic run down.
B585Ford is offline
post #10 of 25 Old 03-07-2014, 09:45 PM
srjd's Avatar
Quoted: 2 Post(s)
B585 I still have my job 1 degas bottle should I look at upgrading. Was the issue with the level being marked on the wrong spot?
srjd is offline
