New to the 6.4 world - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-06-2014, 07:00 PM Thread Starter
stroke'n'drive's Avatar
Hey all,
Just got an 08 f250 6.4 with 94k on it. has dpf delete and intake with a programmer. Im just alittle new to the 6.4s, happened to stumble upon it at the dealer and couldn't leave without it. Ive had multiple 7.3s for the past 4 years and I know this is a whole new ball game. I was just wondering if anyone can give me some tips or direct me to threads on general maintenance and things to look out for. Ive some just looking for some more help. Id appreciate it!
and p.s. whats with people talking about build date and job 1 and such?
stroke'n'drive is offline
post #2 of 7 Old 03-06-2014, 07:11 PM
srjd's Avatar
Quoted: 2 Post(s)
Biggest thing with the 6.4 compared to 7.3 is maintenance. I change my oil (synthetic) every 5000km. I know its over kill to change synthetic that early but don't care its my engine Haha. Also fuel filters I'd check every oil change until you can see a pattern. If your getting fuel from the same station and notice your filters are clean then you can ball park how long to run them each time. I can't get my fuel from the same locations so I check the top one every oil change. Most of the time its super clean so I leave them the odd time you can tell I clearly got a bad tank cause it was very dirty so I changed them. Also drain the water seperator monthly at a minimum. The job number is just the build date you can do a search on it but I wouldn't worry about it to much even if its a job one chances are its all updated.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 7 Old 03-06-2014, 07:13 PM
srjd's Avatar
Quoted: 2 Post(s)
I should add I don't go over 10,000km on fuel filters. Once again probably over kill but peace of mind for me.
srjd is offline
post #4 of 7 Old 03-07-2014, 07:42 AM
AllGo'N'Show's Avatar
^^ All great starting points... water separator and filter info especially... couple more that come to mind which may be slightly over basic info but definitely 6.4 info...
- With your truck running does it sound like a bird chirping from the radiator area? No need to lift hood usually, can hear it just standing out front. If so, belts/tensioners/idlers before a tensioner lets loose on yours, once the tensioner goes she takes all sorts of **** out, get it fixed before she goes. I used used a whack of Gates items this go around after my Ford tensioner replacement lasted a whopping 30,000km.
- Check your coolant hose ends at the motor side, top one is pretty easy grab a light and shine it down, bottom one just crawl under and shine up, look for white connectors. If you have black connectors, wait until the radiator starts leaking (oh it will grab an Alradco as they will be done when you need it) and do the hoses/radiator/t-stats whenever you finally get the radiator leak, or do it preventative if you are worried about downtime/leaks. Most guys use something other than Ford Gold coolant as well as it breaks down pretty quick compared to some of the offerings out their (Shell ELC, Cat EC1, etc..)
- Also check into the "venturi tee" on the 6.4's and make sure the dealer did yours proper, guys are still finding them hooked up backwards, super easy to fix and can save some headaches. Pop a new radiator cap on while you are right there.
- If you have 4x4, pull your 3 allen bolts out the front manual hubs and grease up and ensure the front hubs are in good shape inside, if the c-clip popped off you can usually pop back on and then re-grease with no issues. Also check all your front u-joints and front/rear driveshaft u-joints
- Fluids Fluids Fluids, front diff, rear diff, trans, tcase, all super important if your keeping it forever and want the best mileage out of her. Good high quality fluids will be well worth it especially if you are hauling.
And then you can get to the fun stuff I'm sure I'm missing something still...
EDIT: Def. need another coffee! Missing words all over haha, edited some, let me know if I missed something again.
'16 F450 6.7L Lariat Ult. .:. Tow-Rig
'08 F350 6.4L XL .:. Gone to a new home
Alradco .:. H&S+GH .:. RCD .:. PDR .:. S&B .:. aFe .:. Absolute .:. Fluidampr .:. Toyo .:. Black Rhino
Enjoy horrible service, sub-par quality and made in China product? Mishimoto is your one stop shop!
AllGo'N'Show is offline
post #5 of 7 Old 03-07-2014, 11:42 AM Thread Starter
Thanks for all the info! I was gonna get to greasing her this weekend it's actually going to be nice out. I did have problems with the tensioner pulley not even a week after I got it. I heard a rattling noise and it started getting worse so I took it to the dealer a few days ago and just got it back yesterday thank goodness they took care of it, as they should've. I'm gonna try and do a filter change also this weekend. Thanks again!
post #6 of 7 Old 03-07-2014, 03:59 PM
Front axle ujoints have grease nipples too, first time around I missed it but mine were long gone anyways.
Good luck let us know what you find while your digging around
post #7 of 7 Old 03-07-2014, 09:07 PM
B585Ford's Avatar
See CountryAggies thread in this section. A lot of great info.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
