egr delete - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-06-2014, 01:12 PM Thread Starter
egr delete
Hi guys. thinking of doing the egr delete sometime in the future. I live in sask, Canada. I wanted your opinion on something. Theres a pretty big "reputable" diesel performance shop here in Saskatchewan. Just wanted your advice. First I asked how much for an oil cooler swap. Only because Ive been getting the odd wrench light and it could be a problem in the future. They told me they haven't had to do an oil cooler on a 6.4. Not really a problem with the 6.4. Really? Not what I heard. And they quoted me $1400 before taxes to do an egr delete, sinister or flo pro. Seems pretty damn expensive , considering the kit is like 3-350 bucks. Idk . what you guys think????
nocturnal30 is offline
post #2 of 11 Old 03-06-2014, 04:59 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
The EGR delete is pretty labor intensive. If they lift the cab it shouldn't take more than an hour (after the cab is lifted). Otherwise it took me about 8 hours by myself in my driveway.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #3 of 11 Old 03-07-2014, 04:05 AM Thread Starter
Thanks for the reply. Ill look into it more
post #4 of 11 Old 03-07-2014, 03:55 PM
I've been quoted about $550 for an EGR delete. 1400 seems high, although it is labor intensive like said before because of the different components blocking the lower EGR cooler.
2010 F350 Lariat CCLB - The Tow Rig - S&B Intake. H&S MiniMaxx. 4" FloPro DP. 5" FloPro DP-Back.
2001 Explorer Sport Trac - The Trail Rig - Dana44 Solid Axle Swap. Spring over conversion in the rear. Rolling on 35s with ~14" of travel at all 4 corners
01STrunner is offline
post #5 of 11 Old 03-08-2014, 10:02 AM
I did mine in my driveway in a couple of hours. DIY all the way.
Fussgus is offline
post #6 of 11 Old 03-08-2014, 10:19 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 31 Post(s)
I did mine cab off while I was in there replacing the HPFP. It was a ***** and I cant imagine it being at all easy with cab on.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #7 of 11 Old 03-08-2014, 11:33 AM
StrokiNDieseL's Avatar
patients & a few hrs, remove driverside fender well & degas bottle to make access a bit easier. save the cash & do yourself, spend the $ on something else. Jayson
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
post #8 of 11 Old 03-08-2014, 11:37 AM
srjd's Avatar
Quoted: 2 Post(s)
I tackled mine with a buddy in the driveway. It was a bit frustrating but took 8 hours with really taking our time. I would save your money and just do it yourself.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #9 of 11 Old 03-08-2014, 06:09 PM
floorboy's Avatar
Most of mine was pretty easy except for them $&@ lower cooler bolts. The took longer than anything.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #10 of 11 Old 03-08-2014, 09:51 PM
That was like me, everything went well until it came time for the lower cooler to come out. It was hell but it can be done.
Fussgus is offline
The Following User Says Thank You to Fussgus For This Useful Post:
nocturnal30 (03-11-2014)
