Changing fluid in trans..got questions - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-04-2014, 07:47 AM Thread Starter
Sam Hain's Avatar
Ordered FT-180 filter and 9qts of LV fluid just now from diesel filters. Just to be sure I'm doing this right I wanted to confirm the steps.
- drive truck until trans is up to operating temp
- remove drain plug from trans pan and drain fluid
- take remaining bolts out of pan (drop pan)
- replace internal filter
- replace pan and bolts
- fill trans with new fluid to max hot line
- drive truck
- shut off and check fluid level
does this sound right?
Sam Hain is offline
post #2 of 4 Old 03-06-2014, 08:12 AM Thread Starter
Sam Hain's Avatar
nobody knows?
Sam Hain is offline
post #3 of 4 Old 03-06-2014, 08:50 AM
Quoted: 896 Post(s)
Feedback Score: 3 reviews
Yep. But if your just changing fluid in the pan then you dont really need to drive it to get it up to temp.
Corey@CNCFAB is offline
post #4 of 4 Old 03-06-2014, 10:39 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
thats how i did mine but im pretty sure to check our trans fluid the trans has to be up to temp and in park or nuetral
heres some advice for you
1. when you drop the pan do not be suprised to see a thick coating of fine shavings on the drain pan magnet . clean it off good and re install the magnet into the pan. its just normal wear of the clutches im assuming
2. when I pull the internal filters out, 99% of the time the little salmon/pink o ring thing is stuck up in there. its best to try to get it out with a pick but if its tight i usually take a screw drive and pry in on one side and bend the o ring out of shape and then it will come out. its a metal ring coated in rubber so thats why it bends when you take a screwdriver and pry it out. just make sure if any of the rubber rips when you use the screw driver or pick that you dont leave any pieces up there.
thats about all i got for ya, i think mine took closer to 10qts of fluid. the trans pan gasket is reusable, for the back bolts behind the trans cross member its easiest if you have a swivel socket! good luck!
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
The Following User Says Thank You to travisH3 For This Useful Post:
Sam Hain (03-06-2014)
