Constant Gelling!! - Ford Powerstroke Diesel Forum
post #1 of 20 Old 03-03-2014, 05:52 AM Thread Starter
rumrun111's Avatar
Constant Gelling!!
I have a 2000 7.3. My friend has the 6.4. We both fill up at the same Kwik Trip pumps with Winterized fuel. I have not gelled this winter, down to a minus 41 degrees, this morning it was a minus 27. His 6.4 has gelled 4-5 times this winter with minus 25 below. (he has new filters and always has his truck serviced at a very reputable shop) I understand the 6.4 injectors and fuel system are far more complex, but this is completely uncalled for. I will not suggest he move to a 7.3 as the tranny will never last long enough with his tandem enclosed trailer he hauls everyday. Can anyone provide some input?? He is already looking at a GMC with a LML...I can't blame him.
rumrun111 is offline
post #2 of 20 Old 03-03-2014, 07:22 AM
TD-5's Avatar
Quoted: 3 Post(s)
Your 7.3 has a fuel heater, Ford in their wisdom eliminated the heater from the Horizontal Fuel Conditioning Module shortly after the 08-10 6.4 trucks came out.
He could try installing some like this from Parker/Racor. Not sure if it would completely solve the problem in the extreme cold temps of this winter, but it should help.
http://www.parker.com/literature/Rac...April_2010.pdf
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
The Following User Says Thank You to TD-5 For This Useful Post:
rumrun111 (03-04-2014)
post #3 of 20 Old 03-03-2014, 07:29 AM Thread Starter
rumrun111's Avatar
Thank you for the information! I will pass it to him.
post #4 of 20 Old 03-03-2014, 10:34 AM
bentstroke_02's Avatar
treat the damn fuel. I have yet to gel up
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #5 of 20 Old 03-03-2014, 10:47 AM
Vannnce's Avatar
Quoted: 13 Post(s)
i dont think gelling is a real legit reason to get another truck...
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #6 of 20 Old 03-03-2014, 10:49 AM
theplumbingmedic's Avatar
Same here i was using diesel kleen now i`m using Howes and no problems
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #7 of 20 Old 03-03-2014, 02:07 PM Thread Starter
rumrun111's Avatar
If you are 50 miles from home and have to get 5-$200 tows, I would throw the towel in. There has to be a design flaw or manufacturer remedy, holy crap, it is a 2008.
post #8 of 20 Old 03-03-2014, 03:21 PM
Is your friend using anti gel additive when he fuels up? That could be the simple solution.
2010 F350 Lariat, Ready Lift 2.5" level kit, Toyo Open Country AT2-35 x 12.5 R20 on Worx Tyrant rims
sugelle is offline
post #9 of 20 Old 03-03-2014, 03:30 PM
If it aint a CAT itsa DOG
dieseldan2005's Avatar
Can you prove he is actually gelling or does he have a fuel pressure issue? I ask because my buddy and I were both running Cat C12's in our semis, his kenworth was constantly having gelling like symptoms for the beginning of the winter season. We live north of MPLS/St.Paul so its been WAY colder than anywhere else in north america. My peterbilt hasn't had any of the issues that his KW has had. We get fuel at the same places too. He ended up having a bad spring in his fuel transfer pump. He went from around 32psi to over 80psi of fuel pressure. His issues were cut down by 80%. Now the only time either one of us would gel is if we didn't get number 1 fuel when it got below -10.
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
The Following User Says Thank You to dieseldan2005 For This Useful Post:
post #10 of 20 Old 03-03-2014, 05:14 PM
BuschCountryBoy's Avatar
I just got my 6.4 in December and today it gelled up going down the road and died on me, I was able to limp it back to town and put additive in it then I was alright, I came from owning two cummins and neither gelled up on me. But I agree its alittle extreme to sell a truck because of it, id just take it as a lesson learned.
2008 6.4 crew cab srw, H&S Mini Maxx, 5" downpipe back straight pipe.
BuschCountryBoy is offline
The Following User Says Thank You to BuschCountryBoy For This Useful Post:
