WHERE DOES ALL THE COOLANT GO? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-28-2014, 04:16 AM Thread Starter
I have an '08 F350 (6.4, 75k miles) with a coolant leak. There are no visable signs of a leak. I could lose up to three gallons of fluid a day in the cooling system. the oil level has not changed. I have searched this forum and have found some issues that people have had with the EGR valve and cooler, also the timing cover. Is it possible to lose this much fluid in the cooling system and not have any indication of where it goes?. I'm not getting any engine codes, but I do get the wrench with the reduced power warning. There is no indication I'm burning it out of the exhaust. While I'm not familiar with this truck specifically, I have been rebuilding and repairing my own cars for many years. Any direction from forum members would be a big help.
GTII is offline
post #2 of 10 Old 02-28-2014, 04:31 AM
Jeff-F350's Avatar
Quoted: 14 Post(s)
From what you are saying, with no signs of leaks at all and nothing on the ground, I would say it is burning it. I'm no expert on today's emissions exhaust systems, but the system may be filtering it out, (the burnt coolant), better than you think, and not leave any signs of it coming out the exhaust.
Is it only when you are running it? Or will the level go down when it is sitting, not running?
Jeff-F350 is offline
post #3 of 10 Old 03-03-2014, 08:39 AM
INJEKTER1's Avatar
Quoted: 4 Post(s)
you either have bad EGR's or a bad head gasket.....im voting for head gasket... its under warranty get it in to the dealer asap.....
08 F350 MINI MAXX,5"FLO-PRO DPF DELETE, AFE INTAKE,HID'S,BFG A/T'S ON 20" BMF NOVAKANES,TIMBREMS,BLACKED OUT BUMPERS GRILL,STEPS RACING STRIPES,PAINTED HEADLIGHTS ,FABTECH LEVELD,RCX DUAL STABILISERS
INJEKTER1 is offline
post #4 of 10 Old 03-03-2014, 10:47 AM
Where did you get the truck from?
My guess is that you just bought it used and it was tuned before you got it and the guy blew the head gaskets and your stuck to clean up the mess.....
seafordguy is offline
post #5 of 10 Old 03-04-2014, 04:58 AM Thread Starter
I bought the truck back in 2009 with around 10,000 miles. I have never tuned it. Would a blown head gasket pressurize the cooling system or show some signs in the engine oil?. Neither one is apparent in this case.
GTII is offline
post #6 of 10 Old 03-04-2014, 07:35 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yes blown head gaskets would pressurize the cooling system.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #7 of 10 Old 03-04-2014, 06:14 PM
srjd's Avatar
Quoted: 2 Post(s)
Check around your degas bottle you will know right away. If that's the issue you will see stains of it on the drivers side wheel well frame area
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #8 of 10 Old 03-04-2014, 06:23 PM
bentstroke_02's Avatar
you got warranty take it in no big deal out of your wallet
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #9 of 10 Old 03-05-2014, 02:37 PM
BuschCountryBoy's Avatar
I was told that an issue like this could be a bad egr and causing the antifreeze to go out the exhaust, does this have any truth to it?
2008 6.4 crew cab srw, H&S Mini Maxx, 5" downpipe back straight pipe.
BuschCountryBoy is offline
post #10 of 10 Old 03-06-2014, 12:15 AM
B585Ford's Avatar
I am glad to hear you aren't adding oil....that is never a good place for the coolant to go. Personally, I have never heard of losing this much coolant without there being a definite and visible leak. As stated above, if your HG are bad, you will pressurize the coolant so you should have plenty of signs on the cap and degas bottle, hood, driver's side wheel well, etc.. Not sure where you are from so I don't know how much the snow or salt (if you live in a snowy area) could be masking the leak or keeping you from checking everything very close, but have you checked the radiator and hoses really close. They are a very common source for leaking especially with if you don't have the updated hoses. Finally, since you have worked on cars, have you ever built a DIY coolant pressure tester? You can make 1 for under $20 and that will tell you if you are pressurizing the coolant. Keep in mind a blown HG or ruptured EGR can pressurize the coolant. Also, if you use clear hose, you can watch and see if and when you are producing air bubles. If you are 100% positive there are no external leaks, I would be leaning toward the EGR.
How are you checking for codes. If I am understanding you correctly, you are seeing the wrench light and defueling so there should be a code.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
