did I make a big mistake? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-24-2014, 05:55 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
I did a coolant flush today and instead of being patient and getting the ec1 rated coolant I got some boss lubricants maxx life coolant. Here is what it meets.
PROPERTIES
BOSS MAXX Life Antifreeze meets the following specifications:  ASTM D 3306  ASTM D 4985  ASTM D 6210/6211  TMC of ATA RP392/338  BS 6580
 Chrysler MS 7170  Chrysler MS 9769  Ford ESE M97B44-A  Ford WSS M97B44-D  Ford WSS M97B51-A1  ANFOR R15-601  GM 1825M
 GM 6277M (DEX- COOL)  JASO M325
 Mercedes Benz DBL 7700
It does have the ford wss m97b51-a1 which is the same as ford gold.
The coolant itself looks the same color as the ford gold. Its not green. I really hope I didn't waste a bunch of money and can leave this stuff in.
Thanks in advance
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #2 of 10 Old 02-25-2014, 06:05 AM
I'm guessing it is similar to ford gold just from the spec sheet. Needs pH checked, and checked for suspended solids. What kind of "flush" did you perform.
Stlavsa is offline
post #3 of 10 Old 02-25-2014, 06:06 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
the proper flush is the more important part.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 10 Old 02-25-2014, 08:45 AM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
I've always used the reverse flush machines. I know most people will tell me that was stupid but I've used it at least three times with no issues. I've always ran the ford gold I switch it out lots and run a coolant filter.
srjd is offline
post #5 of 10 Old 02-25-2014, 09:26 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I hate to say it but personally I would get the cat EC-1 coolant. There are no silicates to check and it lasts longer. That's just my opinion.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 10 Old 02-28-2014, 03:22 AM
I dont think its as easy as just switching to a different coolant. People take all kinds of steps to clear out their cooling system before running EC-1 because it gels up and makes a goo.
The Ford gold is specifically designed to put a coating on the cooling system to protect it and prevent cavities. Now if you throw in the EC-1 it gums up the works and then you end up with another clogged oil cooler.
I'm going to personally keep running ford gold and just keep up with it. Its pretty simple to pop off the lower rad hose and drain/ DI flush it every year or so. Takes a matter of minutes.
Stlavsa is offline
post #7 of 10 Old 02-28-2014, 05:59 AM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
Well this stuff looks and smells the same as gold I'm just going to keep it in there. I've always liked the gold for the fact that it has great cavitations protection. The only time gold is bad is when its not changed and I change all my fluids way before they are due so hopefully I'm good to go. Also coolant filter is a must with the gold.
srjd is offline
post #8 of 10 Old 02-28-2014, 06:18 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Srjd between the coolant filter and not neglecting to change your coolant you should be fine
08 F350 cc/sb 4X4
post #9 of 10 Old 02-28-2014, 06:22 AM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
I figured so but this truck makes me paranoid Haha
srjd is offline
post #10 of 10 Old 02-28-2014, 06:24 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yea I hear ya! I am the same way lol
08 F350 cc/sb 4X4
