My own personal test Howes vs. Power Service vs. Stanadyne - Ford Powerstroke Diesel Forum
post #1 of 19 Old 02-23-2014, 06:20 PM Thread Starter
So I have ran power service white bottle or grey bottle since I purchased my truck in October 2012. I haven't had much to compare it to other than running without it and it seemed to improve mpg's when I used it so I have kept on doing that. This year I jelled up and I had about twice the recommended amount in the fuel due to extreme cold temps -40-45 with windchill. I am now using stanadyne for the last few tanks. I haven't noticed a huge improvement or possibly at all? Temps haven't been as cold so not sure if it would jell or not? I picked up some Howes today and hoping this stuff is the best because it is cheaper than Stanadyne and easier to get. It will be a while before I can test all three brands but will update as I see Positives and negatives of each. I probably won't go power service unless it really stands out above the rest. What are some experiences you guys have had as far as jelling? Mpg increase? Etc...
Tjmaxx is offline
post #2 of 19 Old 02-23-2014, 06:40 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
I gelled up with power service white bottle and Motorcraft Anti-Gel. 2 separate tanks, 2 separate additves. I think the base fuel has more to do with it than the additives. They may help a little but it's apparent to me it can't be totally prevented when an area experiences record low temps.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 19 Old 02-23-2014, 08:06 PM
kingbilly68's Avatar
Quoted: 2 Post(s)
My 7.3 seems to like Howes the best. Got my best to date mpg's running it. I put it in an old stabil bottle for easy measuring.
[/SIGPIC]2001 F-250 ecsb 4wd auto 150,xxx miles. 6637 factory straight pipe. Amsoil bypass system. Triple Gauge Pod.
kingbilly68 is offline
post #4 of 19 Old 02-24-2014, 07:54 PM
97HotShot's Avatar
My 7.3 gelled while driving up the interstate in Indiana in -5* weather with Power Service treated fuel.
97 F350 CC DRW 5spd SBC clutch, Swamps tunes, 3" DP 4" straight, Irate stainless bellows, WW2, Amsoil 4510 CAI, Autometer Gauges, Amsoil fluids throughout.
To do list: Plumb SD IC, Full Force Stage 1's, and some different tunes!
97HotShot is offline
post #5 of 19 Old 02-24-2014, 08:04 PM Thread Starter
I'm sure condition of starting fuel has a lot to do with it. But I am noticing a "slight" increase in mpg using the stanadyne vs power service. Looks like we are getting another cold front here in southern Wisconsin so this will give me an opportunity to test the stanadyne in cold weather! I sure hope I don't gel up again, I can't afford to keep changing fuel filters pre-maturally.
Tjmaxx is offline
post #6 of 19 Old 02-25-2014, 11:51 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
we have been running powerservice white bottles on our rigs through the cold months. we havent had any gelling issues but ive tried motorcraft and ran the power service and i cant tell a lick of difference with any of them.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #7 of 19 Old 02-25-2014, 02:14 PM
I've gelled twice this winter. Once using Power Service and once with Howes. Both times with diesel 1, or at least that's what the station clerk claims. Will be trying Stanadyne next.
mangymarmot is offline
post #8 of 19 Old 02-25-2014, 04:02 PM
I gelled using power service in -10 f . I now run Howes and have had no issues.
2010 F350 Lariat, Ready Lift 2.5" level kit, Toyo Open Country AT2-35 x 12.5 R20 on Worx Tyrant rims
sugelle is offline
post #9 of 19 Old 02-25-2014, 04:50 PM
john galt's Avatar
Quoted: 1188 Post(s)
i am running power service. had my truck in storage @ 15 and 20 below no plug in available. Never gelled always fired right up. I think base fuel is more important than anything else i do notice better throtle response and mileage with power service so i use it AND 2 stroke oil
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #10 of 19 Old 02-26-2014, 10:06 AM
F250Marine's Avatar
After using power service and gelling up twice, in -18. I finally listened to the old man and switched to Howe's. I have only had one issue with it and I am almost certain it was the fuel that I got that caused it. I also believe not draining the water regularly will also cause you to gell more often.
With Howe's I have noticed about 1.5 mpgs better then power service. I use a quarter bottle every fill up. A little over kill probably but after sitting on the side of the road freezing my balls off I'm not taking any chances.
2008 F-250 Ext. cab FX4, Spartan tuned 300 EL, S&B intake, 4''DP, 5" flo-pro straight exhaust w/ black 6" MBRP tip.
Coming soon 4.5" Rough Country Lift w/ 18" Ballistic Jesters wrapped in 35X12.5 Nitto Trails
F250Marine is offline
