Back rack mounting and wiring questions - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-23-2014, 03:49 PM Thread Starter
6.4 WNY's Avatar
I have a 08 250. Mounting a Back rack this week and I'd like to put a set of spot /flood LEDs on it. I see there is only one bolt holding the Back rack in place on each side thru the stake pocket. Is this enough strength? And where do you run the wires through and back into the truck? I plan on using upfitter switches in the dash. There are pre made wires under the hood to go through the firewall... Should I use these? Also how do you mount your lights? I really don't want to pay 45.00 for light mounts from back rack
Thanks!!!
Mike
2008 F250 6.4
6.4 WNY is offline
post #2 of 2 Old 02-24-2014, 06:07 PM
SD350's Avatar
Interested in some opinions on the wiring also.
A buddy of mine said his headache rack bolted in the pockets was hard on the bed rails, but that was on a dodge. He re-enforced it by extending it down and bolting into the box mounting bolts somehow. I never got a close look at it.
2008 F350 FX4 King Ranch CC SB
Spartan 275 and 210 Tow as main tunes, AFE CAI
+ Spartan =
SD350 is offline
