forgot how much turbo lag is normal...help me remember - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-22-2014, 06:51 PM Thread Starter
Well as it says. My 08 dpf deleted Spartan tuned with s&b seems to be pretty laggy. I do have 35x13.5 tires and 3.73 gears so that may be part of it but the main problem is just that I forgot how its supposed to feel off the line.
More often than not I run the 210 to tune and shoot around town. Never really in a huge hurry and it pulls great once it reaches a certain psi. But off the line it seems to take a second or 2 to reach say 10psi and really go. Its not horribly slow like there's a major problem but the new 6.7 definitely has substantially better throttle response. As does the duramax I used to have
I just miss a certain oomph that puts you back in your seat from 0mph.
Who knows...maybe it was never there and I just never cared to notice.
Let me know. Thanks
2015 F350 Platinum CCSB SRW
100% stock
SOLD: Black 08 F350 FX4
Spartan tuned
MBPR DP Back straight pipe
20' XD Hoss's
325/60 Duratracs
Leveled
chinaman is offline
post #2 of 12 Old 02-23-2014, 03:38 PM
Capt dong's Avatar
Quoted: 5 Post(s)
no lag here. love my throttle response with my mods. huge reason i dont want to upgrade turbos. slight tap will put you back in the seat immediately.
08 F250 KR
08 F250 XL
Capt dong is offline
post #3 of 12 Old 02-23-2014, 04:54 PM
^^^WHS. Love the throttle response in my truck. I've been running the 250 LL on the Spartan and also have an S&B intake
2006 F250 EC/SB - SOLD
2010 F250 CCSB
Spartan, 5" dp back exhaust, s&b intake, fuel boost 18x9, 315/70r18 toyo mt
06psd6.0 is offline
post #4 of 12 Old 02-23-2014, 08:04 PM
Capt dong's Avatar
Quoted: 5 Post(s)
Check your back pressure and fuel. If that's ok it's possible your vgt is stuck or something like that.
08 F250 KR
08 F250 XL
post #5 of 12 Old 02-23-2014, 09:34 PM
I don't have much lag either. I'm on 235hp street tune with S&B and full exhaust upgrade
2010 F350 Lariat CCLB - The Tow Rig - S&B Intake. H&S MiniMaxx. 4" FloPro DP. 5" FloPro DP-Back.
2001 Explorer Sport Trac - The Trail Rig - Dana44 Solid Axle Swap. Spring over conversion in the rear. Rolling on 35s with ~14" of travel at all 4 corners
01STrunner is offline
post #6 of 12 Old 02-24-2014, 07:53 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Drew did a write up that a fuel sump cured the lag his truck had.
may be onto something I thought was turbo lag..
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #7 of 12 Old 02-25-2014, 03:57 PM Thread Starter
Bp and fuel rail pressure remember to be normal. How would I check a vgt issue?
With regards to the fuel pump. I get plenty of black smoke at the same time I think its kind of laggy. Which makes me think its getting plenty fuel thus not my issue. Is this theory justified?
100% stock
Spartan tuned
20' XD Hoss's
325/60 Duratracs
Leveled
chinaman is offline
post #8 of 12 Old 02-25-2014, 03:59 PM Thread Starter
I mainly just feel its turbo lag...not that its not something else...but almost like its not spooling quick enough. I do notice that on a much higher tune like 275 or 310 off the line throttle response is right on. Just not sure why the lower tunes take a few seconds to get goin.
100% stock
Spartan tuned
20' XD Hoss's
325/60 Duratracs
Leveled
chinaman is offline
post #9 of 12 Old 02-25-2014, 04:53 PM
john galt's Avatar
Quoted: 1102 Post(s)
if I HAD to guess, which i do as i truley dont know. I am betting it is mostly the back pressure not being high enough to spool up right away like the higher power tunes
oops wrong thread....never mind,,,
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #10 of 12 Old 02-25-2014, 06:59 PM
Turn it to your 310. Spartan makes the 210 laggy to make the truck run clean. Instead of dropping fuel into the engine waiting for air they wait for the air and dump the fuel in.
Trouble maker is offline
The Following User Says Thank You to Trouble maker For This Useful Post:
Blue Turd (06-10-2014)
