want to level truck. input please - Ford Powerstroke Diesel Forum
post #1 of 20 Old 02-17-2014, 06:58 PM Thread Starter
sandpiperx1's Avatar
I would like to level the truck 2010 f 350 is there a front level kit 2 inch that is recommended by anyone. have a great day m
2010 F-350 King Ranch 6.4 Diesel fully deleted and in custom mod mode. weekend and trip beast
2009 F-150 XLT Gasser 4.6 3 valve. my company truck. daily driver
2013 BMW 328I modding in motion.
Blueskyglassdesign.com
sandpiperx1 is offline
post #2 of 20 Old 02-17-2014, 07:19 PM
Don't have the 2", mine is 3.5" and I used ready lift and liked it.
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #3 of 20 Old 02-18-2014, 04:39 AM
I'm also interested in the different options. Thinking about 1.5-2" on mine. Don't want too much since I'm always hooked up to a trailer.
2010 F350 Lariat CCLB - The Tow Rig - S&B Intake. H&S MiniMaxx. 4" FloPro DP. 5" FloPro DP-Back.
2001 Explorer Sport Trac - The Trail Rig - Dana44 Solid Axle Swap. Spring over conversion in the rear. Rolling on 35s with ~14" of travel at all 4 corners
01STrunner is offline
post #4 of 20 Old 02-18-2014, 07:32 AM
jkeselis's Avatar
i have the carli suspension 2.5in leveling kit with bilstein shocks. rides excellent, would definitely recommend it!
jkeselis is offline
post #5 of 20 Old 02-19-2014, 10:04 AM
08bigred350's Avatar
Subscribing. I will be leveling this summer.
I have a 3" difference in fender lip height so I'll be doing a 2.5"
Blk450er, did you install an adjustable trac bar at all? How Did it align after the install?
08bigred350 is offline
post #6 of 20 Old 02-19-2014, 10:42 AM
No the kit had a drop down bracket and uses the stock trac bar. Had it aligned after that and they had no issues aligning it
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
The Following User Says Thank You to blk450er For This Useful Post:
08bigred350 (02-19-2014)
post #7 of 20 Old 02-19-2014, 01:51 PM
Ok I've seen a couple kits with the brackets. Thanks for the info.
post #8 of 20 Old 02-19-2014, 06:12 PM
I have a ProComp 2.5 on mine and it's been great
jgos929 is offline
post #9 of 20 Old 02-20-2014, 06:36 AM Thread Starter
Does anyone use a steering stabilizer after the mild 2.5 lift? Just a thought./
post #10 of 20 Old 02-20-2014, 06:48 AM
Yes I have a dual stabilizer on mine
jgos929 is offline
