A/C Blower Quits - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-17-2014, 06:17 PM Thread Starter
TheBigWhit's Avatar
A/C Blower Quits
I just got an '08 F250 with 13K miles on it. Looks like new but I noticed that driving down the highway the A/C blower cuts off and turns back on in a few seconds. This has happened 4 times now in the last 1000 miles.
Any ideas for the cause?
TheBigWhit is offline
post #2 of 4 Old 02-19-2014, 09:12 AM
FlintRidgeFarmSN's Avatar
Strange that is happening on such a little used truck. Mine completely went out last week at 117K. Only thing that i can think of is that the motor could be going out. Its a $150 fix and not very hard to do.
08 F250 Crew Cab SB 4wd
-SCT Livewire with RCD 450 Tune
-Diamond Eye DPF/CAT Delete
-4" MBRP DPF Back with 5" Tip
-Sinister EGR Delete
-35" Nitto Trail Grapplers
At some places they play football...at Alabama we live it.
FlintRidgeFarmSN is offline
The Following User Says Thank You to FlintRidgeFarmSN For This Useful Post:
TheBigWhit (02-19-2014)
post #3 of 4 Old 02-22-2014, 05:51 AM
ACM
My 7.3 started doing that the last couple of years I owned it. It was caused by a tiny leak, when the pressure dropped below a certain point it would shut off, then come back on a few minutes later. Sometimes work for hours, other times it was 5 minutes on, 5 minutes off. $2k later I carried an Autozone recharger and topped it off every fuel stop. Never did find that leak...
ACM is offline
The Following User Says Thank You to ACM For This Useful Post:
TheBigWhit (02-22-2014)
post #4 of 4 Old 06-25-2014, 09:02 AM
banshee-rider's Avatar
Quoted: 7 Post(s)
Garage
Did you ever figure out the problem mine is doing the same thing 05 though.
2005 FORD F250 CREWCAB LARIAT
9 INCH LIFT
37x13.50x20 TOYO M/T'S
PMF TRACTION BLOCKS AND BARS
MBRP 4 INCH TURBO BACK
ARP'S,STAND PIPE'S, DUMMY PLUGS ALL THE UPDATES
SCT LIVEWIRE SRLxx
2008 SUPERDUTY TAILLIGHTS
OPT7 LED HEADLIGHTS AND FOG'S, 50 INCH LED BAR
AMP RESEARCH POWER STEP'S
AIR BAG'S TRAIN HORNS AND AIR COMPRESSOR
CUSTOM STEREO
XDP COOLANT FILTER
PSC HYDRAULIC ASSIST STEERING
RCD EGR DELETE
EXCURSION CENTER CONSOLE
2007 REAR VIEW MIRROR AND MIRROR SWITCH UPGRADE
banshee-rider is offline
