Which Pulley? Or is it the belt? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-14-2014, 03:51 PM Thread Starter
HM-8404's Avatar
I have an '08 that has had a slight "belt" squeak for a while. It has gotten much worse lately and I want to get rid of it. Outside temp nor engine temp affect it. Raising the hood and listening does not really help much with pinpointing where exactly the sound is coming from. I don't want to start replacing pulleys and tensioners, and belt if it is only one. I will no doubt replace the belt when I do the job but is there a sure fire way to determine which pulley, if any, is the culprit?
HM-8404 is offline
post #2 of 2 Old 02-14-2014, 04:03 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
I would replace the belts and tensioners but there can also be a damaged roller on a lifter that causes the exact sound of a belt squeak.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
