NEED SOME ADVICE ON WHAT TO DO WITH THIS TRANSMISSION ISSUE - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-14-2014, 11:21 AM Thread Starter
silver93's Avatar
ok guys the truck is only slipping when it goes from 3-4 or 3-5 ive read where it skips 4 gear. should I order a direct clutch solenoid and try that first before bring it to the transmission shop. when it shifts out of 3 no matter how much throttle you give it, it revs then bangs into the next gear. I try to let off when I feel it about to shift because it hits so damn hard. the trans is a ford factory reman but they are not wanting to honor the warrenty because of the deletes and programmer but all that was on the truck when it was installed at the dealership. what should I do. yes the truck is returned to stock setting right now but does the same thing no matter what tune is on it. yall have been a lot of help with previous issues on this truck. just looking for the right road to take with this issue. I just had a motor and turbos put in last week now this. ive only had the truck 6 weeks. im about ready to blow a gasket!!!!
silver93 is offline
post #2 of 5 Old 02-14-2014, 11:23 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
The modified solenoid fixed my shift flare. Mine would only do it on that shift also.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 5 Old 02-14-2014, 12:29 PM Thread Starter
silver93's Avatar
where did you get the solenoid from?
silver93 is offline
post #4 of 5 Old 02-14-2014, 12:55 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
performance truck products.
08 F350 cc/sb 4X4
post #5 of 5 Old 02-17-2014, 08:08 PM Thread Starter
silver93's Avatar
truck is going in the shop Thursday and ford is going to honor the warrenty on the transmission. thanks for all the input guys.
silver93 is offline
