AC/Heat not working - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-13-2014, 02:36 PM Thread Starter
FlintRidgeFarmSN's Avatar
AC/Heat not working
The unit itself displays everything just fine, just get no response from the blower. Sometimes i can feel the slightest bit of air coming out but it only sometimes does that. Checked the blower connections behind the glovebox and they had power. Don't see any areas where I could be loosing coolant but i topped it off today just to make sure because the levels where low. Also checked the relay and it was fine. Any help would be greatly appreciated.
Thanks,
Sean
08 F250 Crew Cab SB 4wd
-SCT Livewire with RCD 450 Tune
-Diamond Eye DPF/CAT Delete
-4" MBRP DPF Back with 5" Tip
-Sinister EGR Delete
-35" Nitto Trail Grapplers
At some places they play football...at Alabama we live it.
FlintRidgeFarmSN is offline
post #2 of 3 Old 02-14-2014, 04:36 PM
Capt dong's Avatar
Quoted: 5 Post(s)
maybe the blower motor is jammed with debris.
did you check lower drivers side of radiator for leaks.
08 F250 KR
08 F250 XL
Capt dong is offline
post #3 of 3 Old 02-19-2014, 09:01 AM Thread Starter
Ended up having to replace the blower motor, I think that it was just going out so that is why i got some power to it when i had checked it earlier. Thanks for the reply Capt Dong
