Ice... Wreck. - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 02-12-2014, 08:26 PM Thread Starter
zdawg8394's Avatar
Ice... Wreck.
Got a lot of snow and ice in NC today and I was in a parking lot when by girlfriend hollered and I noticed a small car sliding towards my truck. I instinctively floored it and moved just enough causing her to miss my center and hit me in the rear right tire. No damage that I can see thanks to my lift and tires... But is there anything that I should check? How likely is it to shift the axel? It was only a 4-8 mph.
08 F350 6.4 4x4 Lariat CCSB
-BDS 4 inch radius lift - Fox 2.0 shocks - XD monster 20x10 chrome rims - Toyo open country m/t 37/13.50/r20 - Procomp dual steering stabilizer w/fox stabilizers - 2wd valance - HID heads and fogs - escort 8500 x50 blendmounted - CTS insight with dash pod - interior led conversion
"When you nail the throttle in traffic trying to get around someone chr*st I think GM could have mailed me that 400hp faster then I got it out of the truck."
zdawg8394 is offline
post #2 of 13 Old 02-12-2014, 08:54 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
I doubt it...but driving at highway speed should tell you for sure
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 13 Old 02-12-2014, 09:14 PM
B585Ford's Avatar
I was on Interstate last year when a girl went to make a lane change and didn't realize traffic had slowed. She hit me hard enough to knock the truck sideways (almost to 90 degrees). I was going about 55 MPH when she hit me. My truck had a very mild scratch on the rear bumper but it took some nice chunks out of my rim...same thing, she mostly went under the rear of my truck. It tore the h#ll out of her front end. After the wreck, it felt like the truck might be slightly out of alignment so I took it in to the shop that does all my alignments and when they compared it, there was almost no change. I do have traction bars which probably helped, but sounds like I got hit a lot harder than you so you should be fine. Like it was already said, test on the road or go back to the alignment shop that does your work so they can compare numbers.
Superford64 likes this.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #4 of 13 Old 02-12-2014, 09:16 PM Thread Starter
zdawg8394's Avatar
Can they compare numbers on the rear end? And her bumper was all messed up... Ford FTW
post #5 of 13 Old 02-12-2014, 09:17 PM Thread Starter
zdawg8394's Avatar
And I can't tell now since everything is so slick.
post #6 of 13 Old 02-13-2014, 03:08 AM
B585Ford's Avatar
Yes. It is a very handy way to look for an axle being slightly out of place
B585Ford is offline
post #7 of 13 Old 02-13-2014, 08:55 AM Thread Starter
zdawg8394's Avatar
Good deal, thank you
post #8 of 13 Old 02-13-2014, 05:34 PM
Maybe in a few years you might have rear axle seal leak but I bet nothing else or even that.
Good excuse for bigger tires and rims? Yes/No?.. Lol..
GSchretter is offline
post #9 of 13 Old 02-13-2014, 06:11 PM
09SDLariat's Avatar
Quoted: 9 Post(s)
Garage
After spending 1600$ in tires I have the alignment flecked every oil change(my buddies). How ever I was side ways at about 40mph skipping across pavement. So the weight of my the truck at 40sideways and not be out, I believe that you should be ok, it doesnt hurt to have it checked though. If it were me I would. I baby my vehicles though.
09SDLariat is offline
post #10 of 13 Old 02-13-2014, 07:01 PM Thread Starter
zdawg8394's Avatar
Same here. I baby mine also! Thanks for the info!
