SwitchBack LEDs in front, fast flash - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-11-2014, 07:04 AM Thread Starter
MartyG's Avatar
Ok, so after my HID retro, I also put in switchbacks of the front running, Turn signals. Fast flash occurs. Add resistors, connected to the outside wires, which everyone says. Still fast flash. Tried the other wire, still fast flash. Tried the other resistor, still fast flash. Gave up, took to FORD to have the SJB reprogramed to turn off the bulb out feature. STILL fast flash. THey said they did everything according to the instuctions of how to do it. THey have a call into the Special Vehicle Dept. to try and figure it out. They said they have never tried to do this so maybe they are just doing it wrong I don't know.
What else do you guys think it can be, I would have assumed the resistors would stop the fast flash. They are getting warm... I have researched and researched and can't find anything. My last resort would be to order the blue resistors from the retrofit source and try those instead of the gold ones... I don't know what else to try except live with the fast flash???
2010 6.4L F350 Crewcab Lariat Long Bed.
MartyG is offline
post #2 of 8 Old 02-11-2014, 04:10 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
They can't be hooked up right. The lamp outage feature ford did is for the rear only. It's for those who remove the bed and install LEDs. For the front you need resistors. I can't remember which wire I tapped into. I just turned the turn signal on and tested which wire went 12v - 0v. - 12v. Etc. and other side gets grounded.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 8 Old 02-11-2014, 04:13 PM
Quoted: 48 Post(s)
I prefer fast flash personally
drunk on diesel is offline
post #4 of 8 Old 02-11-2014, 04:25 PM Thread Starter
MartyG's Avatar
Can maybe I have the wrong resistors or bad ones. Can someone point me the the right direction of which resistors I need? Thanks in advance
MartyG is offline
post #5 of 8 Old 02-11-2014, 04:54 PM
travisH3's Avatar
Quoted: 2 Post(s)
These are the ones I have
https://www.superbrightleds.com/more...r-kit/190/831/
T-rav
2010 F350 6.4-
travisH3 is offline
post #6 of 8 Old 02-11-2014, 05:23 PM Thread Starter
MartyG's Avatar
Well I have the 3 ohm... thanks. Hopefully this will work. Thanks again!
MartyG is offline
post #7 of 8 Old 02-13-2014, 09:45 PM
tony97gt's Avatar
I never put my resistors in. Just got used to fast flash.
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #8 of 8 Old 02-21-2014, 03:43 PM
V-LEDS have the best bulbs if you can afford it.
Fussgus is offline
