Anybody upgrade their oil cooler? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-10-2014, 12:48 PM Thread Starter
My mechanic told me today that the factory oil coolers on these truck were a weak point. Is it worth upgrading while I do the EGR delete? If so where can I buy a good oil cooler at?
kratos2250 is offline
post #2 of 5 Old 02-10-2014, 03:21 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I would only use an OEM oil cooler personally. I don't know of any company that makes an upgraded oil cooler. The only other system I would do is the bulletproof diesel system.
Bullet Proof Oil Cooler System, 2008-2010 F-Series, 6.4L Half-Kit
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 5 Old 02-10-2014, 06:51 PM
Capt dong's Avatar
Quoted: 5 Post(s)
x2 on oem. They're not weak. They are susceptible to clogging due to silicates in the coolant and debris and casting from the block. A good flush can revitalize a partially clogged cooler and bring down running temps a couple degrees.
08 F250 KR
08 F250 XL
Capt dong is offline
post #4 of 5 Old 02-11-2014, 07:16 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ a good flush and a coolant filter
08 F350 cc/sb 4X4
post #5 of 5 Old 02-12-2014, 01:34 PM
rt_hawk's Avatar
Mine dropped 3-4 degrees after I added a filter for 8k miles and then had a proper flush done...filled it back up with EC-1 Final Charge...now my delta is around 6-8* unless I am towing or my front cover is on...
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
