Just wondering why removing DPF would cause "infinite regens" - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 20 Old 02-07-2014, 11:58 AM Thread Starter
mpo
I have read that you need the tuner to turn off the regens and I have no reason to doubt that information. However, I am trying to understand why. My understanding is that there is a pressure sensor before the DPF that ranges from 0 to 11.6 PSI, and that a back pressure of 7 PSI triggers a regen since that indicates the DPF is getting clogged or "full". So, if there is just a pipe there instead of a DPF, and the back pressure is about 0, then why would a regen ever be triggered?
mpo is offline
post #2 of 20 Old 02-07-2014, 12:05 PM
Sam Hain's Avatar
My guess would be the rear sensor (post DPF) would trigger something wrong and put you in limp mode.
Sam Hain is offline
post #3 of 20 Old 02-07-2014, 12:21 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
it reads pressure wether too much or not enough it will put truck in limp mode without fooling pcm with a tuner
ITS STOCK
SCUFFY828 is offline
post #4 of 20 Old 02-08-2014, 10:22 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
it actualy has to do with the stock tuning. if you drop the DPF you won't immediately go into limp mode or infinite regen. After so many miles the computer forces a regen. since the pressure sensors won't detect a change from before regen to after regen, the computer won't know when to stop the regen (i.e. infinite regen).
However, if you drop the DPF and don't have the pressure sensors plugged in without tuning it will immediately go into limp mode.
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #5 of 20 Old 02-08-2014, 09:19 PM
B585Ford's Avatar
[QUOTE=CountryAggie;8164266]it actualy has to do with the stock tuning. if you drop the DPF you won't immediately go into limp mode or infinite regen. After so many miles the computer forces a regen. since the pressure sensors won't detect a change from before regen to after regen, the computer won't know when to stop the regen (i.e. infinite regen).
^^^WHS. One time when I was changing tunes (my DPF had been deleted for 20k miles) when I was running a SCT, a changed tunes back to stock (because that is how you had to change tunes with the LW) and while I was loading a deleted tune, the tuner died. I wasn't sure if the deleted tune was on my truck or not. Started the truck and it ran fine, then after driving a little ways, it started blowing white smoke cause it went into regen. After it started smoking, it wouldn't quit. When I called SCT and asked why that happened, they explained what Aggie said.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #6 of 20 Old 02-11-2014, 03:15 PM Thread Starter
mpo
Anybody know how many miles?
mpo is offline
post #7 of 20 Old 02-11-2014, 03:18 PM Thread Starter
mpo
I am curious what exactly it needs to sense to come out of regen. I am fairly sure the last EGT (after the DPF) has to read a high temp. I am not sure it needs to see a change in pressure. I am an electronics engineer and I can spoof any sensor with hardware. If the computer is looking for something simple I could simulate that. However there may be a minimum regen cycle time. It may be impossible to know. Well someone knows...
mpo is offline
post #8 of 20 Old 02-11-2014, 04:19 PM
B585Ford's Avatar
I didn't even make it a mile but I did let the truck warm up for several minutes....and again, I had been deleted for 20k miles when this happened.
B585Ford is offline
post #9 of 20 Old 02-14-2014, 11:12 AM
Barry Smith's Avatar
Quoted: 8 Post(s)
I'm not sure but I think the main thing is that it sees "some" change between the sensors like a back fault check on a PLC program.
2014 F-250 6.7 4X4 Crew Cab Black Lariat Black Leather 20"Wheels EZ Lynk PPEI S&B intake. Firestone Air bags, 34 gal. Aux fuel tank.
Barry Smith is offline
post #10 of 20 Old 02-14-2014, 03:28 PM
Quoted: 47 Post(s)
It causes infinite regens to remind you that you are being stupid...
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, Westin Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
