4 wheel high issue - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 Old 02-06-2014, 05:05 PM Thread Starter
Profarm72's Avatar
4 wheel high issue
What's up guys!
Had an issue to come up today while driving around in the snow today and need some help.
Whenever I switched over from 2 wheel to 4 wheel high I could tell that it engaged but after a few minutes I was spinning the tries and the front wasn't pulling.
I pulled over and selected 4 wheel low and it seemed to work just fine for about a mile so I pulled to the shoulder and put it back in 2 wheel drive, went down the road a little further and switched it back over to 4 high and nothing.
Few weeks back everything worked perfectly,
Any idea what might have happened?
2009 F250 FX4 * H&S MINI MAXX WITH HD300 TUNE * 4" STRAIGHT PIPE TURBO BACK * BANKS CAI * EGR/COOLER DELETE * RANCH HAND * LIFTED W/35's * WITH MORE MODS TO COME.
Profarm72 is offline
post #2 of 16 Old 02-07-2014, 05:22 AM
Think theres a recent thread on this, could be the vacuum sensor thing, vacuum lines, or hub seals/hubs.
Search in this section and I think you'll find it. Most people replaced the part for liek 65 bucks and 10 mins of work on the fan shroud and it fixed it. A few people had bad hubs though. I actually have the same thing on my truck. I just lock the manual hubs and will look into it after winter.
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
post #3 of 16 Old 02-07-2014, 05:25 AM
Sorry here ya go, I lied, it was n drivetrain problems;
4x4 not engaging
No, that's not the link shoot. I can't find it, but it's some vacuum switch. TravisH3 knows and will most likely post on here in a few, he had the same issue tried the sensor, nothing, had to replace hub(s). I need to just pony up and buy the part to try it and return it if it isn't it. Need to see if local place carries it to try.
PArt; http://www.ebay.com/bhp/ford-vacuum-solenoid
post #4 of 16 Old 02-07-2014, 05:40 AM Thread Starter
Profarm72's Avatar
So do you know where I can find this vacuum switch thing on the truck, I just had the truck in the shop so maybe they knocked something off.
post #5 of 16 Old 02-07-2014, 06:15 AM
Sure, just open hood, left top of fan shroud. Mine is WHITE so I am guessing it's bad. I called the local dealer they said I can't just swap one out for a new one and return it if it's not that, so probably just order it, pick it up, then resell it or soemthing if it isn't htat.
I am guessing mine is original(100% sure it is) and it looks pretty nasty. Actually I need to text a local member and see if I can try his this weekend real fast.
post #6 of 16 Old 02-07-2014, 06:16 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
As stated above its on the fan shroud on the passenger side. I will go outside when I get a chance and take a picture.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #7 of 16 Old 02-07-2014, 05:07 PM Thread Starter
Profarm72's Avatar
Thanks for the info guys, I'll take a look tomorrow and see if I can find it.
post #8 of 16 Old 02-08-2014, 09:25 PM
B585Ford's Avatar
I am pretty sure all the responses are wrong. I am betting your truck, which according to your location is a Texas truck, was pissed at being in snow and that's why it aint workin.
powerstroken00b likes this.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #9 of 16 Old 02-09-2014, 02:23 AM
Big_Smokey's Avatar
Quoted: 9 Post(s)
ha.... Yah this guy nailed it.
But on a more serious note.....Mine did a similiar thing... only worked when i put the hubs in manual. Ended up being vacuum lines and the sensor.
Big_Smokey is offline
post #10 of 16 Old 02-09-2014, 02:15 PM Thread Starter
Profarm72's Avatar
I know that's right! it's usually just a bunch of ice but this time around we actually got some snow, it was kinda nice!
I checked out the box on the fan shroud like others had mentioned but it appeared to be all hooked up.
Is there a way to test this thing or no?
