Slight shudder turns into bad when towing heavy?? - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By GregsSD
  • 1 Post By jhauling
post #1 of 7 Old 02-06-2014, 12:48 PM Thread Starter
jpfanner's Avatar
Ok here's the quick and dirty. I've started noticing horrible fuel mileage this winter and now a shudder right at initial acceleration. It was very slight at first and seemed to happen more when turning so I thought my junk LS was just slipping clutches. Then I started noticing on deceleration I felt it, slight at first, now from 35mph on down to a stop it shudders like I have Swamper Boggers on! Well the shop found some loose bolts on the front part of my two piece drive shaft so they tightened those up but it's still shuddering. That was yesterday. Well today I had to pull a 12k grain vac about 90 miles. From a stop under accelleartion it shuddered like crazy. It was wet and nasty pavement so I thought maybe LS rear end, but then again something just isn't adding up. Oil was just changed and there didn't seem to be any fuel in oil. Once you get going the shuddering goes away. It SEEMS driveline related BUT I'm also concerned about a broke piston perhaps?
I've also had an EBP code a couple times and this morning there was a contribution code on #3 and a turbo boost code. But I cleared the codes and they have not returned. I'm at a loss here. thoughts?
2008 CCSB, King Ranch, Spartan Tuned, RCD EGR Delete, RCD Cold Air Intake, AFE CAI, AFE 4in DP, AFE 5in DP back, FASS 95gph, 275/65r20 Nitto Terra Grapplers, PMF Stage 2 trac bars, Elite Up-pipes, 6.0 manifolds, ARP studs, RCD Valve Springs, Chrome-Moly Pushrods, Detroit Locker.
jpfanner is offline
post #2 of 7 Old 02-06-2014, 02:23 PM
B585Ford's Avatar
Did tightening the drive shaft help? Any chance your TC is the cause?
Mileage will be down in the winter if you are getting winter blend diesel. Did you have truck last winter to confirm this isn't just winter blend? Is it hand calced mileage?
Any chance the EBP sensor is frozen?
Contribution codes are always concerning....a piston or injector can be the problem and neither are good. Can you manually check compression? Do you have access to IDS?
Any white or black smoke? Have you tried the blow by pressure generic test with the oil fill cap?
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #3 of 7 Old 02-07-2014, 06:59 AM Thread Starter
jpfanner's Avatar
OK I don't think tightening the driveshaft helped and I'm ruling out engine problems. I'm thinking TC. Symptoms are more pronounced.
When you let out of the throttle and coast there is vibration. As it starts downshifting below 35mph it's considerably worse. Also, you get an odd vibration when cruising and you have to barely barely touch the throttle. Like 3-5% throttle input... it seems to have something to do with the TC...but is there anything else that would cause vibration to change under backpressure load?
jpfanner is offline
post #4 of 7 Old 02-07-2014, 11:40 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
It's not your LS clutches, because that won't cause vibrations when you are going straight.
Check your driveshaft, could be bad u-joints, worn out carrier bearing, or could be that your carrier bearing needs a spacer to bring your driveline into better alignment.
john galt likes this.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #5 of 7 Old 02-07-2014, 05:57 PM
B585Ford's Avatar
My best bet is that EBP code and contribution code are a coincidence. Maybe your EBP sensor froze or something like that. It wouldn't hurt to check that sometime, but based on what you are saying, this sounds much more like drivetrain than engine. A while back there was a guy having similar symptoms and it turned out to be the brake switch and vss. He replaced that and problem was solved.
B585Ford is offline
post #6 of 7 Old 02-11-2014, 10:22 PM
I had a similar problem but in the end it turned out to be a small rubber boot on the driveshaft that needed grease. You have to buy the needle to grease it otherwise it doesn't come with a grease nipple. Dont hurt to try it.
jhauling is offline
post #7 of 7 Old 02-11-2014, 11:16 PM
john galt's Avatar
Quoted: 1500 Post(s)
^^^^^^ this
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
