DPF Delete - Pros and Cons - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 26 Old 02-05-2014, 02:11 PM Thread Starter
ezzrider's Avatar
My 2008 F250 6.4 is nearing the end of my warranty period. I am considering doing the DFP Delete. I have did not do it previously due to warranty concerns. I have a company that will do it to include taking of the current exhaust/DPF and installing new pipes without the DPF stuff. That way I could always put the old pipe configuration back on. I am told they are all bolt on to the current frame. They will also reprogram the existing electronics and get me up to an additional 50 HP and around 20MPG I am told for around $1600. They say it will take about half a day for the job. For those of you that have already had the DPF delete done in various fashions what are the Pros and Cons? Also does $1600 sound like a fair price. Do not have a listing of the new parts. Thanks.
ezzrider is offline
post #2 of 26 Old 02-05-2014, 02:53 PM
I'm certainly no expert and have only had my rig a month but here is my experience.
If your primary objective is to get rid of the DPF and CAT in order to increase your MPG and durability, along with a 70 HP bump, your cheapest route is to get the DPF-R 4.0+ and DPF pipe. I got mine from Performance Truck Products for around $700.
If you can wrench a little it's not too bad of a job to take out the DPF and CAT yourself. The tuner module is super easy and is plug and play. The module also turns off the EGR (which is a good thing).
If you want to get wild and have lots of HP you'd need to get a "pre-ban" tuner with a variety of tunes. These will run you lots more $$$. If you want to PM me we can discuss details and I'll share with you what I've learned. Hope this helps.
mhutch2 is offline
post #3 of 26 Old 02-05-2014, 03:05 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
There are no cons but do not buy into the 20MPG bull crap
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #4 of 26 Old 02-05-2014, 03:53 PM
Capt dong's Avatar
Quoted: 5 Post(s)
pros:
better mpgs
little to no fuel dilution
less equipment failure
lighter truck
cons:
more black smoke from exhaust but some might see it as a good thing. personally i wish my engine didnt produce any smoke at all but cleans up pretty good later in the rpms and gears.
people hating you for rolling coal.
accidentally rolling coal so thick at all the cars at a traffic light that they cant move and having one of the cars follow you to your destination to give you a dirty look.
not passing local emissions tests.
citations from law enforcement.
08 F250 KR
08 F250 XL
Capt dong is offline
post #5 of 26 Old 02-05-2014, 04:12 PM
Quoted: 277 Post(s)
dam, you may should dial back your LBF
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #6 of 26 Old 02-05-2014, 05:05 PM
No cons other than black smoke when you're on it and a dirtied rear quarter panel.
I'd do some research on here though on what tuner you want to use.
seafordguy is offline
post #7 of 26 Old 02-05-2014, 05:14 PM
Capt dong's Avatar
Quoted: 5 Post(s)
haha my lbf has been on zero forever. i dunno what happened that particular instance.
08 F250 KR
08 F250 XL
post #8 of 26 Old 02-05-2014, 05:42 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
IF i were you. id do some serious reading up on this topic before you pay someone to do something like that. Do a tuner that will allow you to delete the dpf and just buy a straight pipe and put it on in your driveway...simple hand tools wratchets and wrenches and a bottle of spray lube.....and a buddy for a hand dropping the 50lb DPF down.
4" flopro exhaust system..BOLT ON is around 400 to 450. Plus whatever tuner unit you find that supports the DPF delete.
Also DPF-R is a route you can go. you can do it and stock or that and an option to add 70hp i think......Dont know much about this route, but its around 500 bucks for the setup the last time i looked. Just make sure you search a bit because this is a pretty simple project for anyone that can spell wrench
GSchretter likes this.
Big_Smokey is offline
post #9 of 26 Old 02-06-2014, 04:12 AM
Quoted: 2 Post(s)
i installed a DPF-R 4.0+ on my dads truck about 6 weeks ago. he was looking for the same thing you are... but it only cost $700 from PTP.. I did a small write up and review of it in this thread:
Gearbox Z DPF-R 4.0 Plus Review
keep on reading to figure out what it is you really want, but i would not let some shop just flash my truck, and not be able to "return to stock" without having to go back to ford for the stock flash.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #10 of 26 Old 02-06-2014, 10:41 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Tons of pros as shown above. I don't know what Capt is doing, but I don't hardly smoke AT ALL. Only of I literally floor it. And then it cleans up quick. You have to drive like you are driving a turbo vehicle, roll into the skinny pedal. Can't just mash it all the time.
But as far as having a shop tune it I would shy away. Use a known tuner that deals with just this (ie Spartan, H&S, innovative, gearhead).
Sent from AutoGuide.com App
Rocweiller likes this.
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
