Idling too high in gear - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-04-2014, 12:23 PM Thread Starter
lancinfish's Avatar
Send a message via AIM to lancinfish
Not sure why, but when I got in my truck this morning and cranked it up, it is idling around 800 RPMs. This is both in drive, reverse, neutral and park. Not sure what is causing this, but its really quite a pain in the a$$. Anyone have any idea what could cause this? I am not getting any codes, and otherwise the truck is running perfect. I need to get this fixed quick because its a pita for around town driving.
2008 F-350 LWB CC 4x4 Lariat
Leveled
Diamon Eye downpipe back exhaust & Hushpower muffler
SCT Livewire
AFE Intake
Line-X
Gear Double Pump 20" Rims
Tokyo Open Country A/T II 35x12.50R20
"Peace is that brief glorious moment in history when everybody stands around reloading".
Thomas Jefferson
lancinfish is offline
post #2 of 11 Old 02-04-2014, 05:05 PM
Guessing you are running a tune..
Can you go back to stock and then unhook both neg battery cables and reinstall cables and drive around?
Pull cables to reset most standard settings (learning)
What tune +hp are you running?
EGR still instAlled?
Maintenance? Fuel filters?
Check air intake between filter to turbo.
GSchretter is offline
post #3 of 11 Old 02-04-2014, 05:18 PM
Quoted: 2 Post(s)
Check what he said above
Your SCT might not read all the codes. I'm willing to bet one of the three exhaust sensors has gone bad. Get a better code reader and I one of them are bad. $60 at your local stealership
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #4 of 11 Old 02-04-2014, 05:41 PM Thread Starter
lancinfish's Avatar
I pulled the codes with my Edge Insight, not my SCT. I can go back to stock, but how long can a I drive around before the "Mandatory Regen" kicks in. I don't want to cause myself a problem.
My buddy runs a shop, but is slammed until Friday and just doesn't have time to plug it in until Friday. Is there any way to check it without the computer?
Leveled
SCT Livewire
AFE Intake
Line-X
Thomas Jefferson
post #5 of 11 Old 02-05-2014, 04:24 AM
Max distance is around 500 miles until a regen, if you have your EGR disabled/removed you will make it that far but with EGR functioning about 200 miles max.
post #6 of 11 Old 02-05-2014, 03:25 PM Thread Starter
lancinfish's Avatar
I will try returning it to stock and see what happens after I unhook the cables.
Oil is due for changing, but is only 5000 miles on it. Fuel filter was changed with oil, as well as the air filter is clean. I am running the tow tune on the SCT. not sure what HP it is, but its not much. I do still have my EGR in place. Drove it again today and everything looks good. I can't find anything obvious wrong except that the RPM's are too high.
Leveled
SCT Livewire
AFE Intake
Line-X
Thomas Jefferson
post #7 of 11 Old 02-05-2014, 08:24 PM
imk0001's Avatar
I was having the same problem with mine when I first deleted my DPF. Did you check to make sure that all of your sensors were seated properly? My post DPF wasn't seated right and it caused the same problem to happen. Even if you have a delete pipe w/ no bungs, the sensors still need to be plugged in to prevent what we both went through. These truck are too smart these days.
imk0001 is offline
post #8 of 11 Old 02-06-2014, 03:42 AM Thread Starter
lancinfish's Avatar
The dpf has been gone for quite a while. Sine this just started, I am hearing this must be a bad exhaust sensor.
Should the truck have a trouble code for a bad sensor? Neither my edge or SCT are showing any codes. I really don't want to pay for computer diagnostics if I don't have to.
Leveled
SCT Livewire
AFE Intake
Line-X
Thomas Jefferson
post #9 of 11 Old 02-09-2014, 05:19 PM Thread Starter
lancinfish's Avatar
After plugging the truck in Friday with the Ford Computer at my buddies shop, we found nothing. The computer shows that everything is working properly and I still have a high idle sitting around 800 RPM's. We have tried it all, from putting the tuning back to stock, forcing the computer to do all the diagnostics, etc... Everything looks fine.
So the thoughts are that the Pedal Assembly is got a problem. There was a report of this being a fix on their computer system. What do yall think? The pedal assembly is not cheap.
Leveled
SCT Livewire
AFE Intake
Line-X
Thomas Jefferson
post #10 of 11 Old 02-09-2014, 05:39 PM
08PowerstrokeFX4's Avatar
Like p8ntballn2 said, it is most likely one of the exhaust sensors are bad. My best guess would be the rear most sensor, usually the one that gives guys the most problems when taking it out of the dpf.
F250 CCSB 6.4L Powerstroke
Spartan Tuned, ATS Trans, Sinister Diesel Goodies, Elite Diesel Goodies, and a bunch under the hood.
We miss you Ron. Thanks for everything you did for us and sharing your knowledge!
08PowerstrokeFX4 is offline
