drip.. drip... freakin' drip... drip.. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-04-2014, 11:30 AM Thread Starter
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
my rig is marking it's territory..
It has to be the front cover or the bed plate..
dang it..
here is the curiosity, though: It's likely dripped at least a couple of quarts since my last oil change, but the stick reads full, still...
I'm not a dummy.. I open fumoto valve, and start draining- then remove filter housing (which opens the valve to release oil; a lot of folks don't know that)- and let WARM/HOT oil drain for at least twenty minutes every time..
then I close fumoto valve, install new filter and o-ring, seat it, fill it with 15 quarts of oil...
there is not a hint of fuel in my oil according to blackstone, but it seems to be overfilled all the same... there is no weep on these systems, it's 'sposed to be a closed system; if you see oil, you've got a leak..
freakin drip drip drip...
I drain about 13~14 quarts out, assume the missing quarts are due to dripping, install the fifteen requested, and go about my business...
freakin' drip drip drip..
'round about a month or so after changing oil, the dripping stops (as I assume the level evens off below wherever the leak is) and there won't be a leak until I change oil again... the oil never drops below full on the dipstick, and I always get at least 13~14 quarts out of it...
either these things don't hold freakin 15 quarts as advertised, and I'm overfilling, these things DO have a weep somewhere for over pressure/fill, or I need to file for mineral rights of this engine because it's producing oil that is untainted with either coolant or fuel..
does anyone else have anything like this happening to their rigs?
drewactual is offline
post #2 of 5 Old 02-05-2014, 06:37 AM
muntu's Avatar
maybe.
cps o-ring or maybe crack in the dipstick tube at the block. don't know how anyone can get an exact dip stick reading...POS engineering.
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #3 of 5 Old 02-05-2014, 12:34 PM
WoodBoy's Avatar
I always use 14-14.5 quarts of oil and run at halfway between full and low on my dipstick so I can read it. Other wise if you run 15 you cant ever tell if it were to start increasing
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 5 Old 02-05-2014, 03:49 PM
pops250's Avatar
Thats what i do too. If i put in 15 its overfull. Mine leaks too though but not enough to drip, just stays wet. Ive had it ti dealerships too many times for this so i have just given up and keep it checked. Bugs the fire out of me though.
H&S tuned. B&W gooseneck hitch with Companion 5th wheel. Helwig rear sway bar. Edge CTS monitor. Dieselsite coolant filter. Rancho 9000 shocks. Airlift 5000 air bags with onboard compressor. Viair onboard air with 5 gal tank. Flo-pro stainless 4 in. exhaust.
pops250 is offline
post #5 of 5 Old 02-06-2014, 07:58 AM
Drop some dye in the oil and start peaking around. You know how those leaks go....They travel, so it may be coming from above? Also, check your oil cooler?
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
