Updated radiator hose questions - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-04-2014, 02:21 AM Thread Starter
I know that Ford updated the 6.4 radiator hoses to be double O-rings in lieu of singles some time back. Were ALL THREE hoses updated ? I know in confidence that the upper hose part # AC3Z-8260-A was updated as I picked that one up from my local stealership yesterday. They did not have the lower hoses in stock for me to look at. I am going to go to another stealership today and get the balance of what I need. Were BOTH lower hoses updated or do I just need one as I have found conflicting information.
The part #'s for the lower hoses are AC3Z-8286-A and AC3Z-8286-B
Some info lists AC3Z-8286-A to be the only lower hose updated. Is this correct ? Do I only need to replace the upper hose and the one lower ?
cjglenn is offline
post #2 of 8 Old 02-04-2014, 05:34 PM
Clayton1985's Avatar
I only got one lower hose when I bought the updated hoses.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #3 of 8 Old 02-05-2014, 06:11 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ me too.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 8 Old 02-05-2014, 12:32 PM Thread Starter
OK. I went to my local dealership and had them pull all three(3) hoses. ONLY TWO ARE UPDATED. The upper and one of the lower sections(half hose that connects to the engine) The lower half hose that connect from the radiator has NOT been updated by Ford.
cjglenn is offline
post #5 of 8 Old 02-05-2014, 12:34 PM Thread Starter
UPDATE HOSE PART #'s
AC3Z-8286-A and AC3Z-8260-A
cjglenn is offline
post #6 of 8 Old 02-05-2014, 01:22 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I am pretty sure that's the part number I posted in your other thread.
08 F350 cc/sb 4X4
post #7 of 8 Old 02-05-2014, 03:56 PM
Capt dong's Avatar
Quoted: 5 Post(s)
i swear all three hoses are updated. replaced both lower hoses with my new rad. i guess ill follow along and say only 2 of the hoses have bee updated until i get under my truck and look. cant tell from this pic.
08 F250 KR
08 F250 XL
Capt dong is offline
post #8 of 8 Old 02-06-2014, 06:22 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I also replaced both lower hoses but IIRC only one lower hose had the white end. I don't remember for sure tho.
08 F350 cc/sb 4X4
