Bought my first diesel 09 f250 - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 02-03-2014, 11:50 AM Thread Starter
Got it with 93,000 miles on it bone stock. Been reading on here and I'm learning but still would like to clear a few things up. So my plan is to delete the DFP, EGR, upgrade the intercooler pipe, and put a CAI on it. To do this I need to order a Spartan? Or can I just delete this stuff. I just want the truck to run good and live a long life.
kratos2250 is offline
post #2 of 14 Old 02-03-2014, 11:55 AM
Sam Hain's Avatar
Do a search, plenty of info on the subject. Spartan, H&S, or SCT (offroad versions) will tune the truck and turn off the egr/dpf. You have to use a tuner to turn these off, if you just remove them truck won't run.
Sam Hain is offline
post #3 of 14 Old 02-03-2014, 12:07 PM Thread Starter
I read up on the sticky on here, and I understand some of it. It's just the tuner I'm not following. So When I do the dpf/egr, CAI and the intercooler pipe. I just hook up the Spartan and it takes care of everything. I don't need to take it to a dyno and have it tuned there? Also other than these mods is there anything else I should do before the tune? I'm not gonna go crazy and mod this truck out it is my DD and I sink most of my time and efforts into my 03 cobra. I just want to do a few things to make it a better truck.
post #4 of 14 Old 02-03-2014, 01:30 PM
Hey buddy, yeah, you just gotta hook up the tuner and upload the tune to the ECM. It's not quite the same animal as your Termi... Tuners have put a lot of time and effort into making sure the tunes for these trucks work, it's not quite as much of a unique experience as when you get your Termi tuned. Post pics of the Cobra!
Sideswipe505 is offline
post #5 of 14 Old 02-03-2014, 04:04 PM Thread Starter
Car is a blast to drive makes 591rwhp 552rwtq runs low 10s Now it will look great being towed behind the black f250. Date stamp is wrong this was only about a year ago
pops250 likes this.
post #6 of 14 Old 02-03-2014, 04:46 PM
Pretty car man! You do the deletes the same time with the tuner, it will make a huge difference in performance, reliability if driven with some sense, and improve fuel mileage. Your truck has pretty low mileage so if it's been taken care of you should be ok.
beaslyb is offline
post #7 of 14 Old 02-03-2014, 05:24 PM Thread Starter
Ok so I hook the Spartan tuner up then do all of these deletes. Probably do most of it the same day. Then it's all tuned in the Spartan and it makes all the adjustments itself? How much money are we talking for these mods? I'm gonna also do some research on the banks systems.
post #8 of 14 Old 02-03-2014, 07:29 PM
B585Ford's Avatar
Nice. That will look good behind your F250.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #9 of 14 Old 02-03-2014, 07:36 PM
B585Ford's Avatar
You can do the CAI any time. Other than that, you have to run tunes for a deleted vehicle so you will need your tuner for that. I assume you are referring to the cold side pipe for the intercooler. Are you planning on doing the intake elbow also? Like others already said, the tuners you can use are Spartan, H&S (race version), or SCT (off road version).
B585Ford is offline
post #10 of 14 Old 02-03-2014, 07:53 PM
Steve-0-'s Avatar
I'd say skip the CAI. I put an aFe Stage 2 in my 03 6.0 and saw a decrease in flow/power. Stick with the stock intake, save $400 and do the Zoodad mod if you want better flow. Not sure if the intake is that much different on the 6.4, but just my 2 cents.
03 F250 Lariat CCSB - 6.0L - ARP Studs - Sinister Coolant Filter - BPD FICM - 4" Straight Exhaust - Blue Spring - SCT w/ Looney Wild - Leveling Kit - 35" Mt/2's
"Steve runs on Copenhagen and Monster.. It helps him focus." -My Boss
Steve-0- is offline
