Any reason not to use Shell Rotella Ultra ELC - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-02-2014, 02:52 PM Thread Starter
spock91's Avatar
Quoted: 6 Post(s)
As the title states? I couldn't find Cat ELC so I ordered a case of Rotella ULTRA ELC.
Just wondering if it is compatible with Cat ELC. Done some searches but it's not clear, to me at least.
Thanks
Spock
spock91 is online now
post #2 of 7 Old 02-02-2014, 05:57 PM
Jim Truett's Avatar
That is probably the best ELC available right now. Cat EC-1 rated, right on the bottle. You will want to do a full flush and mix with distilled water for the fill. I also highly recommend using an Airlift tool to refill the block. It prevents many headaches....
I have had it in my truck for two years now, and is still perfectly clear with no crust in the degas bottle like the ford gold.
'08 F250 CC 6.4PSD
Never start an argument with an idiot. They will drag you down to their level, then beat you with experience.
Jim Truett is offline
post #3 of 7 Old 02-02-2014, 06:34 PM
Vannnce's Avatar
Quoted: 13 Post(s)
is ultra the red stuff? I believe i use just the normal shell rotella ELC which is red and i would reccomend it to anyone. x2 on a complete flush and refill though
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #4 of 7 Old 02-02-2014, 08:08 PM
Jim Truett's Avatar
There is nothing wrong with the red Rotella ELC, but it is not as good as the Ultra which is gold in color. Ultra was designed specifically for long life with minimal maintenance in EGR equipped diesel engines.
Shell Rotella® Products - Shell Rotella
'08 F250 CC 6.4PSD
post #5 of 7 Old 02-03-2014, 08:10 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yes the ultra elc is the best stuff right now and is ec-1 rated. Rotella elc will work fine tho and is better than ford gold.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 7 Old 02-03-2014, 12:08 PM Thread Starter
spock91's Avatar
Quoted: 6 Post(s)
Thanks for the reply's....
What I wanted to hear. And yes full flush with EGR delete and thermostat change.
Will be a long weekend I think.
Thanks again
Spock
post #7 of 7 Old 02-05-2014, 01:36 PM
I went with the Fleetrite(International branded ELC) which is Cat EC-1 and Navistar B-3 rated. IT is what is sued by Navistar in the Navistar maxxforce engine(our 6.4)
cjglenn is offline
