No glow plug light? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-02-2014, 02:00 AM Thread Starter
No glow plug light?
Hey guys anyone run into this before? On initial cold start glow plug light comes on as normal.....any other start after, It does not come on again, doesn't even flash the light. Keep in mind it's winter here so "cold"......
This is not how the truck was previously....before anytime you cycled the key the glow light came on, summer or winter.
cuda66 is offline
post #2 of 5 Old 02-02-2014, 02:34 AM
How long is the truck off before you try to start it again? Mine does this if it is still warm. I've seen it where it might be off for up to an hour and the truck stayed warm enough.
Tjmaxx is offline
post #3 of 5 Old 02-02-2014, 06:16 AM Thread Starter
Hummm...it never mattered before on my truck....anytime you cycled the key the light would come on...hot, cold, summer, winter. Now it appears to only come on when it needs to. (Which is ok as well).
I thought the light always came on anytime you cycled the key as a self check?
cuda66 is offline
post #4 of 5 Old 02-02-2014, 08:04 AM
Mine has only come on when it's been sitting for a while. Even in the winter when I think it would be too cold it doesn't come on and she fires right up without hesitation. I guess the truck stays warm for a fairly long time even in cold temperatures.
01STrunner is offline
post #5 of 5 Old 02-02-2014, 11:40 AM Thread Starter
Ok I guess I'll consider it normal and go from here....worse case it just won't start...lol...thanks guys for the input!
cuda66 is offline
